Adding Entry to existing Access List appears at the end of Access List
tariqmansoor
Hi guys,
I am having issues in adding new entries to an existing access list, When i add the entry to access list and then issue
 #sh access-lists
The new entries are at the end of Access List but i want them to appear on the top or in a place where i can control.
Is there any way we can do this with out removing all the entries and then putting them back as the router i am adding access list entries is a production router.
Thansk for your input.
As an example lets say you want to add a line into acl ACT between line 10 and line 20
ip access-list extended ACT
15 deny ip 10.26.0.0 0.0.0.255 172.16.10.0 0.0.0.255
Jon
Jon Marshall
Really depends on what type of acl it is. If you do a
sh access-list
do you get numbered lines or not ?
If you don't then easiest thing to do is create a new acl in notepad which is a copy of your existing acl with the additional lines. Copy this back into the config and then simply update the acl under the interface ie.
int fa0/0
ip access-group in/out
Jon
Thansk i do get numbered line when i
sh access list
Extended IP access list 105
10 deny ip 10.26.0.0 0.0.0.255 10.10.10.0 0.0.0.255 (31573 matches)
20 deny ip 10.26.0.0 0.0.0.255 10.0.0.0 0.0.0.255
30 permit ip 10.26.0.0 0.0.0.255 any (2823 matches)
40 permit tcp any host 10.26.0.100 eq 3389
Extended IP access list ACT
10 permit ip 10.26.0.0 0.0.0.255 10.10.10.0 0.0.0.255 (796 matches)
20 permit ip 10.26.0.0 0.0.0.255 10.0.0.0 0.0.0.255
How Can we add new entry at our desired location in the Acces list.?
Cheers,
Jon
tkalfaoglu
Even when I enter my access list with numbers,
show run
shows the same access list without numbers..
my access list starts like:
ip access-list extended ACL-INFRASTRUCTURE-IN
10 deny tcp any any fragments
20 deny udp any any fragments
etc...
what can I do to preserve the line numbers?
many thanks, -t
