4331 ISR, Direct upgrade from 3.16.9S to 17.6.3 or 17.3.5
MauryJ
Hello all,
We have an ISR-4331 that is running IOS XE 3.16.09.5 and need to get it upgraded.   I see that both 17.6.3 and 17.3.5 are recommended releases.
I did see that a ROMMON update is required.   Besides that, would we be able to upgrade directly to either of the recommended releases?   I didn't find any prerequisite versions, or upgrade paths, mentioned in the release notes.
georgehewittuk1
Yes I've upgraded with this 'jump' before from 3.x to 17.x i believe it is because of the architecture of the packages- as you righty stated need to make sure ROMMON is performed before as a pre-req as it's commonly outdated.
11 Replies 11
georgehewittuk1
That's good to know, thanks @georgehewittuk1 .
And thanks @Leo Laohoo for the link to your installation guide.
Hi All,
We have a new router to be deploy at site - the router model is Cisco ISR 4431 and firmware release is version 17.3.5
So I would like whether the 17.3.5 is the latest version ? or do we need to upgrade to 17.6.x release?
Your advise and recommendation is highly appreciated.
Start testing 17.9.3.
Which one do i need to download ? the first one or the other with (No Payload Encryption) ?
1)Cisco ISR 4400 Series IOS XE Universal
isr4400-universalk9.17.09.03a.SPA.bin
Advisories
30-Mar-2023
737.55 MB
2)Cisco ISR 4400 Series IOS XE Universal-No Payload Encryption
isr4400-universalk9_npe.17.09.03a.SPA.bin
Advisories
30-Mar-2023
741.18 MB
Download the first one because it supports SSH.
Thank you for you advice and suggestion.
How do I check the md5sum verification for this firmware version file?
Where can I find if this is the correct checksum, generated by Cisco?
There is no need to check the MD5 checksum because if the MD5 do not match, the Install Mode procedure will stop without rebooting the router.
Hi All, need further assistance on how to login my router.
Previously i have perform below configuration to our cisco router ISR 4431 series
aaa new-model
aaa authentication login default group tacacs+ local line enable
aaa authentication login async none
aaa authentication enable default group tacacs+ enable
aaa authorization console
aaa authorization exec default group tacacs+ if-authenticated
aaa accounting exec default
action-type start-stop
group tacacs+
aaa accounting commands 1 default
action-type stop-only
group tacacs+
aaa accounting commands 15 default
group tacacs+
BUT after my console access to the router have ended & try to login again, the below error messages occur & I cannot login to the router as I'm not set any username & password previously.
User Access Verification
Username:
*May 26 06:12:59.442 UTC: %AAA-3-BADSERVERTYPEERROR: Cannot process authentication server type tacacs+ (UNKNOWN)
Please help me on how to login access to the router. TQ
