Additional ADSL connection on existing BGP on the same router, same ISP
cinmar1957
I have 2 leaseline which is configured using BGP. and I would like to use an extra ADSL connection for HTTP request only.
MAIN and BACKUP leaseline is configured using BGP with no issues.
-> ip nat inside source route-map BACKUP interface FastEthernet0/1/1 overload
-> ip nat inside source route-map MAIN interface GigabitEthernet0/1 overload
Since I have an extra ADSL line I am adding this statement:
ip nat inside source route-map ADSL interface Dialer1 overload
NOTE: All interfaces are tested individually without issues.
Overall my configuration for the 3 connecction are:
But, when I do show ip route, the defaul gateway will go to ADSL not the BGP,
Disabling the ADSL, the default gateway returns back to BGP.
My question, can I keep the BGP route as default while keeping the ADSL for http traffic on the same router?
I forgot to mention that you need to also remove the "ppp ipcp route default" statement from the Dialer1 interface so that a default route is not installed through this interface.
7 Replies 7
Harold Ritter
You probably get your default route via DHCP or static route, which makes it normal for this route to be preferred over the default received via BGP. You would need to use PBR to send the HTTP traffic via the ADSL link. Normal routing will not help here.
http://www.cisco.com/en/US/docs/switches/metro/me3600x_3800x/software/release/15.3_3_S/configuration/guide/swpbr.html
This is my configuration:
interface Embedded-Service-Engine0/0
no ip address
shutdown
interface GigabitEthernet0/0
description ADSL
no ip address
ip nat outside
ip virtual-reassembly in
duplex auto
speed auto
pppoe enable group global
pppoe-client dial-pool-number 10
description MAIN_LEASELINE
ip address 11.11.11.11 255.255.255.252
ip nat outside
duplex auto
speed auto
interface FastEthernet0/1/0
no ip address
shutdown
duplex auto
speed auto
description BACKUP_LEASELINE
ip address 22.22.22.22 255.255.255.252
ip nat outside
duplex auto
speed auto
interface GigabitEthernet0/0/0
no ip address
interface GigabitEthernet0/0/1
switchport access vlan 2
no ip address
interface GigabitEthernet0/0/2
switchport access vlan 3
no ip address
interface GigabitEthernet0/0/3
switchport access vlan 4
no ip address
interface Vlan1
description VLAN PRIVATE NETWORK
ip nat inside
ip policy route-map TOADSL
interface Vlan2
  no ip address
interface Vlan3
  no ip address
interface Vlan4
  no ip address
interface Dialer1
ip address negotiated
ip nat outside
ip virtual-reassembly in max-fragments 64 max-reassemblies 512
encapsulation ppp
dialer pool 10
ppp authentication pap callin
ppp pap sent-username xxx password 7 xxxxx
ppp ipcp dns request accept
ppp ipcp address accept
ip policy route-map
router bgp 200
bgp log-neighbor-changes
network 111.111.111.111 mask 255.255.255.248
network 222.222.222.222 mask 255.255.255.248
neighbor 11.11.11.10 remote-as 100
neighbor 11.11.11.10 update-source GigabitEthernet0/1
neighbor 11.11.11.10 route-map MAINLL in
neighbor 22.22.22.21 remote-as 100
neighbor 22.22.22.21 update-source FastEthernet0/1/1
neighbor 22.22.22.21 route-map BACKUPLL in
maximum-paths 2
ip forward-protocol nd
ip http server
ip http authentication local
ip http secure-server
ip dns server
access-list 1 permit any
access-list 101 permit tcp host 192.168.1.0 0.0.0.255 any eq www
access-list 101 deny   ip any any
route-map MAIN permit 10
match ip address 1
match interface GigabitEthernet0/1
route-map MAINLL permit 10
set local-preference 110
route-map BACKUP permit 10
match ip address 1
match interface FastEthernet0/1/1
route-map BACKUPLL permit 10
set local-preference 90
route-map TOADSL permit 10
match ip address 101
match interface Dialer1
control-plane
line con 0
line aux 0
Harold Ritter
You need to change the "match interface Dialer1" to "set interface Dialer1" in the TOADSL route-map that is used for PBR. You also need to have a "ip nat inside source" statement for the Dialer1 interface, which deleted from the configuration.
route-map ADSL permit 10
Hi Harold,
Thank you for the  quick reply.
I modified the configuration as what you've suggested. But still with no luck. When I do 's ip route' the default gateway is the ADSL not via BGP.
Here is the edited config.
no ip address
shutdown
description ADSL
no ip address
ip nat outside
duplex auto
speed auto
ip nat outside
duplex auto
speed auto
no ip address
shutdown
duplex auto
speed auto
ip nat outside
duplex auto
speed auto
no ip address
no ip address
no ip address
no ip address
interface Vlan1
ip nat inside
interface Vlan2
  no ip address
interface Vlan3
  no ip address
interface Vlan4
  no ip address
interface Dialer1
ip nat outside
encapsulation ppp
dialer pool 10
ip policy route-map
router bgp 200
maximum-paths 2
ip http server
ip dns server
match ip address 1
match ip address 1
match ip address 1
control-plane
line con 0
line aux 0
Hi Harold,
Youre a life saver. Thank you so much...
You are very welcome.
