09-17-2006 09:30 PM - edited 03-03-2019 02:01 PM
Hi Team
I have a PRI which is connected by multiple dial-in users.After a particular user A dial in,other users couldn't get connected
*Jun 13 11:48:12.487: Se3/0:12 LCP: I TERMREQ [Open] id 7 len 16 (0x174575A7003CCD7400000000)
*Jun 13 11:48:12.487: Se3/0:12 LCP: O TERMACK [Open] id 7 len 4
*Jun 13 11:48:12.487: Se3/0:12 PPP: Sending Acct Event[Down] id[E]
*Jun 13 11:48:12.487: Se3/0:12 IPCP: Remove link info for cef entry 10.254.59.1
*Jun 13 11:48:12.487: Se3/0:12 IPCP: Route to 10.254.59.1 still needed by Se3/0:18(user A)
*Jun 13 11:48:12.487: Se3/0:12 IPCP: State is Closed
*Jun 13 11:48:12.491: Se3/0:12 PPP: Phase is TERMINATING
*Jun 13 11:48:12.767: %ISDN-6-DISCONNECT: Interface Serial3/0:12 disconnected from 66511926 dialin, call lasted 1845 seconds
---but once user A disconnects,other user can get connected.
any thoughts?
much appreciated.
Tony
09-17-2006 10:23 PM
Pretty little info to draw any conclusions but Ok.
This is probably due to adress-pool exhaustion.
UserA then gets the least-used IP.
If you are not using a pool, it is probably a misconfiguration in the radius server?
Leo
09-17-2006 11:07 PM
Dear Leo
Thank you very much for the quick response and explanation.Much appreciated.
Neither an address pool nor a radius server is used.here is the interface config:
interface Serial3/0:15
ip address 172.31.170.1 255.255.255.0
encapsulation ppp
dialer map ip 172.31.170.8 broadcast 02150540667
dialer map ip 172.31.170.72 broadcast 84400369
dialer map ip 172.31.170.9 broadcast 02038912117
dialer map ip 172.31.170.201 broadcast 85638033
dialer map ip 172.31.170.10 broadcast 02150624238
dialer-group 1
isdn switch-type primary-net5
isdn incoming-voice data
no peer default ip address
no cdp enable
ppp authentication chap
dialer-list 1 protocol ip permit
Any thoughts?
Warmest Regards
Tony
09-18-2006 03:29 AM
If you say they cannot get connected, do you mean they are unable to authenticate or that other users cannot send/receive any traffic?
The output from: deb ppp neg may show interesting info regarding this issue. Did you already try that?
Leo
09-18-2006 05:04 AM
Hi Leo
Everything works fine.The remote users can dial in and get connected.But once the user A dials in,no one else can get connected.After user A disconnected,other users can dial in and get connected again.
I am waiting for the cu to send me the output of debug ppp neg.Hopefully it will show sth useful.
Thank you again for your help.Much appreciated.
Best regards
Tony
09-18-2006 11:54 AM
I would like to have another look when the ppp neg output is posted.
09-26-2006 07:05 PM
Hi Leo
Sorry for coming back to you so late.the cu just sent me the debug ppp ne .Please c the attachment.
problem:when a user dials in from 665111926,it injects a host route 10.254.59.1 into routing table.when other users dial in,they can get connected for a couple of seconds then get dropped.IPCP complains that the host route 10.254.59.1 is still needed by cef .
any ideas?
thank you very much for your help.
tony
