additional Ethernet port for a 2611XM
dstehle
Will a NM-1FE-TX work in a 2611XM? We need another Ethernet port and find that a NM-E1 is too slow. Or will a NM-1FE2W work?
Edison Ortiz
Either will work but I recommend going with the latter as the former has reached its EOL status
http://www.cisco.com/en/US/prod/collateral/routers/ps259/product_data_sheet09186a00801aa71c.html
Minimum software required 12.2(8)T - maximum modules in platform 1.
Edit: Table 3 indicates the module NM-1FE2W is only supported on 2691, thus you are out of luck in terms of support with the 2611XM
Edison.
so...the NM-1FE-TX will work but the NM-1FE2W will not?
Neither module will work on your router.
http://www.cisco.com/en/US/products/hw/routers/ps274/products_data_sheet09186a0080091b89.html
See Table 2
You are limited to Ethernet modules..
__
Edison.
