10-01-2016 02:07 AM - edited 03-05-2019 07:10 AM
Explain briefly with examples, the concept of ‘Administrative Distance ‘ in relation to routing protocols.
10-01-2016 04:28 AM
AD is the first criterion used to determine which routing protocol to use, if two protocols provide route information for the same destination.
Here are a few defaults:
EIGRP 90
OSPF 110
RIP 120
Note the smaller the value, the more reliable the protocol, so let's say we have a router configured with both EIGRP and RIP, the former route would get installed, because it's more reliable.
Martin
10-01-2016 07:22 AM
Thanks for your answer. I need a brief answer. Please explain briefly ,concept and examples.
Shalika
10-02-2016 10:21 AM
Plz Guys help me
10-03-2016 05:57 AM
Disclaimer
The Author of this posting offers the information contained within this posting without consideration and with the reader's understanding that there's no implied or expressed suitability or fitness for any purpose. Information provided is for informational purposes only and should not be construed as rendering professional advice of any kind. Usage of this posting's information is solely at reader's own risk.
Liability Disclaimer
In no event shall Author be liable for any damages wha2tsoever (including, without limitation, damages for loss of use, data or profit) arising out of the use or inability to use the posting's information even if Author has been advised of the possibility of such damage.
Posting
The concept is, a router might have the network prefix provided from more than one routing source. If it does, AD provides a metric for which source, for a particular network prefix, to prefer.
As Martin has noted, Cisco has default ADs assigned to different routing protocols.
So, say for example, a router receives 192.168.1.0/24 from EIGRP, OSPF and RIP, which does it chose? Since, by default, EIGRP has the lowest AD, the router will use EIGRP's information for how to get to 192.168.1.0/24.
Now also suppose, the same router receives 192.168.2.0/24, from OSPF and RIP, but not EIGRP. In this case, by default, it would chose to use OSPF's information.
Static routes also support AD, so if you had:
ip route 192.168.3.0 255.255.255.0 10.1.1.1 200
ip route 192.168.3.0 255.255.255.0 10.1.1.2 20
It would use the second static route, as it has a lower AD than the first static route.
