ADSL Configuration on Cisco 887 router
271266waqar
I am installing a Cisco 887 to a ADSL2 Circuit and I cannot connect to the ADSL eventhough the show interface shows that both the ATM0.1 and Dialler 0 is up.
The configuration of the router is below.
Building configuration...
Current configuration : 5980 bytes
! Last configuration change at 11:12:58 PCTime Wed Aug 3 2011 by cisco
! NVRAM config last updated at 11:12:55 PCTime Wed Aug 3 2011 by cisco
version 15.0
no service pad
service tcp-keepalives-in
service tcp-keepalives-out
service timestamps debug datetime msec localtime show-timezone
service timestamps log datetime msec localtime show-timezone
service password-encryption
service sequence-numbers
hostname ScollayVoiceAK
boot-start-marker
boot-end-marker
security authentication failure rate 3 log
security passwords min-length 6
logging buffered 51200
logging console critical
enable secret 5 $1$dhiV$EqeIlEkU4EwgKdttQuWWU.
no aaa new-model
memory-size iomem 10
clock timezone PCTime 12
clock summer-time PCTime date Mar 16 2003 3:00 Oct 5 2003 2:00
crypto pki trustpoint TP-self-signed-910627735
enrollment selfsigned
subject-name cn=IOS-Self-Signed-Certificate-910627735
revocation-check none
rsakeypair TP-self-signed-910627735
no ip source-route
ip dhcp excluded-address 10.10.101.254
ip dhcp pool ccp-pool1
   import all
   network 10.10.101.0 255.255.255.0
   default-router 10.10.101.254
ip cef
no ip bootp server
no ip domain lookup
ip domain name ScollayVoiceAK.com
no ipv6 cef
license udi pid CISCO887-SEC-K9 sn FGL152425EQ
username everphone privilege 15 secret 5 $1$v5..$LiKiPSSWrRB6YcFl6PGD2/
ip tcp synwait-time 10
ip ssh time-out 60
ip ssh authentication-retries 2
interface BRI0
no ip address
no ip redirects
no ip unreachables
no ip proxy-arp
ip flow ingress
encapsulation hdlc
shutdown
isdn termination multidrop
interface ATM0
no ip address
no ip redirects
no ip unreachables
no ip proxy-arp
ip flow ingress
no atm ilmi-keepalive
interface ATM0.1 point-to-point
description $ES_WAN$$FW_OUTSIDE$
ip flow ingress
pvc 0/100
  encapsulation aal5snap
  protocol ppp dialer
  dialer pool-member 1
interface FastEthernet0
interface FastEthernet1
interface FastEthernet2
interface FastEthernet3
interface Vlan1
description $ETH-SW-LAUNCH$$INTF-INFO-HWIC 4ESW$$ES_LAN$$FW_INSIDE$
ip address 10.10.101.254 255.255.255.0
no ip redirects
no ip unreachables
no ip proxy-arp
ip flow ingress
ip nat inside
ip virtual-reassembly
ip tcp adjust-mss 1452
interface Dialer0
ip address negotiated
no ip redirects
no ip unreachables
no ip proxy-arp
ip flow ingress
ip nat outside
encapsulation ppp
dialer pool 1
dialer-group 1
ppp authentication pap callin
ppp pap sent-username scollaytelak.xadsl@xtra.co.nz password 7 0007120810425B57
no cdp enable
ip forward-protocol nd
ip http server
ip http authentication local
ip http secure-server
ip http timeout-policy idle 60 life 86400 requests 10000
ip nat inside source static udp 10.10.101.201 5060 interface Dialer0 5060
ip nat inside source static udp 10.10.101.254 5070 interface Dialer0 5070
ip nat inside source list 1 interface Dialer0 overload
ip route 0.0.0.0 0.0.0.0 125.236.227.6
logging trap debugging
access-list 1 remark INSIDE_IF=Vlan1
access-list 1 remark CCP_ACL Category=2
access-list 1 permit 10.10.101.0 0.0.0.255
dialer-list 1 protocol ip permit
no cdp run
control-plane
line con 0
login local
no modem enable
transport output telnet
line aux 0
login local
line vty 0 4
privilege level 15
login local
transport input telnet ssh
scheduler max-task-time 5000
scheduler allocate 4000 1000
scheduler interval 500
end
9 Replies 9
johnlloyd_13
Level 9
Level 9
hi,
kindly re-configure your static default route and test again.
no ip route 0.0.0.0 0.0.0.0 125.236.227.6
ip route 0.0.0.0 0.0.0.0 dailer0
I have done that and I could see that the ADSL is now up.  However I cannot access the Internet.
hi,
sorry, made a typo earlier. it should be:
ip route 0.0.0.0 0.0.0.0 dialer0
please check again.
I have set the ip route 0.0.0.0 0.0.0.0 dialer0 and I can now see the ADSL up.  However I cannot access the Internet from any host.  I am able to ping any Public IP Address from the host but cannot do a http connection.
Can you post the ipconfig from your PC? I'm suspecting this could be a DNS issue.
Attached is the IPconfig from the pc
How can i add a DNS to the router config
Hi johnlloyd13
I can access the internet if I manually input the dns server address in the nic settings of the pc.  How can I set this so that the router issue the dns address to the local hosts when they request for a dhcp address.
Hi johnlloyd13
I have managed to include the dns server in the router and I can now access the internet.  Thanx much for the help
sorry was busy at work. glad it's working for you now. please rate if posts were helpful. thanks!
