ADSL connection issues
shamax_1983
Level 3
Level 3
Hi Guys,
One of our clients had a poor ADSL connection and the ISP checked on it and advised us that the ADSL is currently not on ADSL2+ ( which I could verify from the router ) and they changed the connection profile from their end.
After the change, when I do the "show controllers VDSL 0" command , it does not show me the uplink parameters ( as highlighted below)  although the site still has Internet access.
Is this a bug ? or can someone explain me what is going on here ?
Appreciate your help.
NZ_R01#show controllers vdSL 0
Controller VDSL 0 is UP
Daemon Status:           Up
                        XTU-R (DS)              XTU-C (US)
Chip Vendor ID:         'BDCM'                   'IKNS'
Chip Vendor Specific:   0x0000                   0x0001
Chip Vendor Country:    0xB500                   0xB500
Modem Vendor ID:        'CSCO'                   '    '
Modem Vendor Specific:  0x4602                   0x0000
Modem Vendor Country:   0xB500                   0x0000
Serial Number Near:    FTX160883LB C887VA- 15.2(4)M
Serial Number Far:     ^A
Modem Version Near:    15.2(4)M
Modem Version Far:     0x0001
Modem Status:            TC Sync (Showtime!)
DSL Config Mode:         AUTO
Trained Mode:            G.992.5 (ADSL2+) Annex A
TC Mode:                 ATM
Selftest Result:         0x00
DELT configuration:      disabled
DELT state:              not running
Trellis:                 ON                       OFF
SRA:                     disabled                        disabled
SRA count:              0                       0
Bit swap:                enabled                         enabled
Bit swap count:         0                       0
Line Attenuation:         7.5 dB                  4.0 dB
Signal Attenuation:       9.4 dB                  3.6 dB
Noise Margin:            12.1 dB                 dB
Attainable Rate:        25564 kbits/s            0 kbits/s
Actual Power:             0.0 dBm                10.1 dBm
Total FECC:             0                        0
Total ES:               0                        1
Total SES:              0                        0
Total LOSS:             0                        0
Total UAS:              45                       45
Total LPRS:             0                        0
Total LOFS:             0                        0
Total LOLS:             0                        0
Full inits:             1
Failed full inits:      0
Short inits:            0
Failed short inits:     0
Firmware        Source          File Name (version)
VDSL            embedded        VDSL_LINUX_DEV_01212008 (1)
Modem FW  Version:      120306_1254-4.02L.03.A2pv6C035j.d23j
Modem PHY Version:      A2pv6C035j.d23j
Vendor Version:         Ap6v35j.23j 68
                  DS Channel1     DS Channel0   US Channel1       US Channel0
Speed (kbps):             0            21080             0               110
SRA Previous Speed:       0                0             0                 0
Total Cells:              0        102764074             0                 0
User Cells:               0           446678             0                 0
Reed-Solomon EC:          0                0             0                 0
CRC Errors:               0                0             0                 1
Header Errors:            0                0             0                 0
Interleave (ms):       0.00             7.92          0.00             15.00
Actual INP:            0.00             2.03          0.00              2.00
Training Log :  Stopped
Training Log Filename : flash:vdsllog.bin
Shamal
johnlloyd_13
Level 9
Level 9
hi,
did you try to re-train your ADSL link and got the same result? try to shut/no shut ATM.
you might also want to consider the 'Speed' parameter instead.
Hi johnlloyd_13,
Sorry for the late reply, Yes I reloaded the router ( I can't shut/no Shut ATM because I'm doing everything remotely, I think reloading the router would have the same effect on the ATM interface ?? ).
The Interesting thing is that, I got one of the users in the site to do a speedtest.net test from behind the router and he is getting around 5Mbps/0.5Mbps dowb/up speeds ( but varies with time ) which doesn't make sense.
Please have a look at the "show int dial 1" output, ATM and Dialer configs for this. Please let me know if you can see anything obvious.
Router_NZ_R01#show int di 1
Dialer1 is up, line protocol is up (spoofing)
  Hardware is Unknown
  Internet address is 125.237.xxx.xxx/32
  MTU 1500 bytes, BW 56 Kbit/sec, DLY 20000 usec,
     reliability 255/255, txload 255/255, rxload 236/255
  Encapsulation PPP, LCP Closed, loopback not set
  Keepalive set (10 sec)
  DTR is pulsed for 1 seconds on reset
  Interface is bound to Vi2
  Last input never, output never, output hang never
  Last clearing of "show interface" counters 17:00:38
  Queueing strategy: fifo
  Output queue: 0/40 (size/max)
  5 minute input rate 52000 bits/sec, 6 packets/sec
     98068 packets input, 47660493 bytes
     101384 packets output, 28163255 bytes
Bound to:
Virtual-Access2 is up, line protocol is up
  Hardware is Virtual Access interface
  MTU 1500 bytes, BW 500 Kbit/sec, DLY 20000 usec,
     reliability 255/255, txload 48/255, rxload 27/255
  Encapsulation PPP, LCP Open
  Open: IPCP
  PPPoATM vaccess, cloned from Dialer1
  Vaccess status 0x44
  Bound to ATM0 VCD: 1, VPI: 0, VCI: 100, loopback not set
  DTR is pulsed for 5 seconds on reset
  Interface is bound to Di1 (Encapsulation PPP)
  Last input 00:00:00, output never, output hang never
  Last clearing of "show interface" counters 16:59:17
  5 minute input rate 53000 bits/sec, 8 packets/sec
  5 minute output rate 95000 bits/sec, 13 packets/sec
     103915 packets input, 47891847 bytes, 0 no buffer
     Received 0 broadcasts (0 IP multicasts)
     0 input errors, 0 CRC, 0 frame, 0 overrun, 0 ignored, 0 abort
     101391 packets output, 28163372 bytes, 0 underruns
     0 unknown protocol drops
     0 carrier transitions
Router_NZ_R01#
Router_NZ_R01#show run int di 1
Building configuration...
Current configuration : 515 bytes
interface Dialer1
ip address negotiated
ip access-group in-from-world in
ip access-group out-to-world out
ip nat outside
ip inspect out-to-world out
ip virtual-reassembly in
encapsulation ppp
logging event subif-link-status
dialer pool 1
dialer-group 1
ppp authentication pap chap callin
ppp chap hostname xxxxxxxxx@xxx.co.nz
ppp chap password 7 xxxxxxxxxxxxxxxxxxxxx
ppp pap sent-username xxxxxxxxxxx@xxx.co.nz password 7 xxxxxxxxxxxxx
no cdp enable
crypto map CRY-MAP-DIALER1
end
interface ATM0
description ADSL Interface
no ip address
ip mask-reply
ip directed-broadcast
ip flow ingress
no atm ilmi-keepalive
pvc 0/100
  encapsulation aal5mux ppp dialer
  dialer pool-member 1
end
Hi there,
Configure the vdsl controller and try again after rebooting the router:
conf t
Controller vdsl 0
Operating-mode ! Here you choose the mode that better works.. Not always auto does it
End
Wr
however, in my opinion there are issues with the sp because the attainable rate (upstream) is 0. That is not a good value at all.
The dB are not matching amazing values either.
Hope this helps
Alessio
