Simply OSPF NBMA question
Istvan kelemen
Hey!
LAB: OSPF over multipoint frame relay (hub and 2 spokers).
Neighbors are not coming up.
Wireshark capture is showing 1-1 hello packets to 192.168.0.66 and to 192.168.0.67 but that's all.
Neighbor command is not shown in the sh run, and the prioriti is 0.
R1
interface Loopback0
ip address 1.1.1.1 255.255.255.0
interface Serial0/0.1 multipoint
ip address 192.168.0.65 255.255.255.192
ip ospf priority 0
frame-relay map ip 192.168.0.66 102 broadcast
frame-relay map ip 192.168.0.67 103 broadcast
router ospf 1
router-id 1.1.1.1
log-adjacency-changes
network 1.1.1.0 0.0.0.0 area 0
network 192.168.0.64 0.0.0.63 area 0
FR map is active
Neighbor ID     Pri   State           Dead Time   Address         Interface
N/A               0   ATTEMPT/DROTHER 00:01:21    192.168.0.66    Serial0/0.1
N/A               0   ATTEMPT/DROTHER 00:01:21    192.168.0.67    Serial0/0.1
Serial0/0.1 is up, line protocol is up
  Internet Address 192.168.0.65/26, Area 0
  Process ID 1, Router ID 1.1.1.1, Network Type NON_BROADCAST, Cost: 64
  Transmit Delay is 1 sec, State DROTHER, Priority 0
  No designated router on this network
  No backup designated router on this network
  Timer intervals configured, Hello 30, Dead 120, Wait 120, Retransmit 5
    oob-resync timeout 120
    Hello due in 00:00:00
  Supports Link-local Signaling (LLS)
  Index 1/1, flood queue length 0
  Next 0x0(0)/0x0(0)
  Last flood scan length is 0, maximum is 0
  Last flood scan time is 0 msec, maximum is 0 msec
  Neighbor Count is 0, Adjacent neighbor count is 0
  Suppress hello for 0 neighbor(s)
R2
interface Loopback0
ip address 2.2.2.2 255.255.255.0
ip address 192.168.0.66 255.255.255.192
ip ospf priority 0
frame-relay map ip 192.168.0.65 201 broadcast
frame-relay map ip 192.168.0.67 201 broadcast
router ospf 1
router-id 2.2.2.2
network 2.2.2.0 0.0.0.0 area 0
1.1.1.1           0   INIT/DROTHER    00:01:39    192.168.0.65    Serial0/0.1
  Internet Address 192.168.0.66/26, Area 0
  Process ID 1, Router ID 2.2.2.2, Network Type NON_BROADCAST, Cost: 64
    Hello due in 00:00:19
  Next 0x0(0)/0x0(0)
  Neighbor Count is 1, Adjacent neighbor count is 0
R3
interface Loopback0
ip address 3.3.3.3 255.255.255.0
ip address 192.168.0.67 255.255.255.192
ip ospf priority 0
frame-relay map ip 192.168.0.65 301 broadcast
frame-relay map ip 192.168.0.67 301 broadcast
router ospf 1
router-id 3.3.3.3
network 3.3.3.0 0.0.0.0 area 0
1.1.1.1           0   INIT/DROTHER    00:00:30    192.168.0.65    Serial0/0.1
  Internet Address 192.168.0.67/26, Area 0
  Process ID 1, Router ID 3.3.3.3, Network Type NON_BROADCAST, Cost: 64
    Hello due in 00:00:16
  Next 0x0(0)/0x0(0)
Thanks!
Richard Burts
Istvan
The essence of your problem is that assigning ip ospf priority 0 on all of the serial interfaces is preventing any router from becoming DR. And on a multipoint connection some router needs to function as DR. My suggestion is to configure the priority to 1 on R1. I believe that this will solve your problem.
Rick
Rick
Yea thanks! Exactly! I just watched Jeremy's tutorial video 5 times to get that detail, but thanks!!
