ADSL line quality
fsoffia
hallo I have a problem with a cisco1801 IOS (c180x-broadband-mz.123-8.YI2.bin) that does not get sync on an ADSL line. On the same ADSL line a cisco1841 does get the sync.
This is the "sh dsl int atm0/0/0" from cisco1841:
cisco1841#sh dsl int atm0/0/0
Alcatel 20150 chipset information
ATU-R (DS) ATU-C (US)
Modem Status: Showtime (DMTDSL_SHOWTIME)
DSL Mode: ITU G.992.1 (G.DMT) Annex A
ITU STD NUM: 0x01 0x1
Vendor ID: 'ALCB' 'TSTC'
Vendor Specific: 0x0000 0x0000
Vendor Country: 0x00 0xB5
Capacity Used: 24% 83%
Noise Margin: 32.5 dB 12.0 dB
Output Power: 20.0 dBm 12.0 dBm
Attenuation: 42.0 dB 24.0 dB
Defect Status: None None
Last Fail Code: Handshake or init message invalid or had bad CRC
Selftest Result: 0x00
Subfunction: 0x15
Interrupts: 1335 (0 spurious)
PHY Access Err: 0
Activations: 1
LED Status: ON
LED On Time: 100
LED Off Time: 100
Init FW: embedded
Operation FW: embedded
SW Version: 3.8131
FW Version: 0x1A04
Interleave Fast Interleave Fast
Speed (kbps): 1504 0 608 0
Cells: 0 0 283651 0
Reed-Solomon EC: 0 0 0 0
CRC Errors: 0 0 0 0
Header Errors: 0 0 0 0
Bit Errors: 0 0
BER Valid sec: 0 0
BER Invalid sec: 0 0
LOM Monitoring : Disabled
DMT Bits Per Bin
00: 0 0 0 0 0 0 0 4 6 7 8 9 9 A A A
10: A A 9 A 9 9 9 9 8 8 8 7 7 6 0 0
20: 0 0 0 0 0 0 0 0 0 0 0 0 0 0 2 2
30: 2 2 2 2 3 3 3 4 4 4 4 4 5 5 5 4
40: 0 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4
50: 4 4 4 3 3 0 2 3 4 4 4 4 4 2 5 5
60: 5 5 5 5 5 5 5 5 5 4 2 2 4 4 4 5
70: 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 4
80: 0 4 4 3 3 4 4 4 4 4 4 4 4 4 4 4
90: 4 4 4 4 3 0 3 3 3 3 3 2 2 2 2 2
A0: 2 2 2 3 3 3 3 2 2 2 2 2 2 2 2 2
B0: 2 2 0 2 2 2 2 2 2 2 2 2 2 2 0 2
C0: 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0
D0: 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0
E0: 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0
F0: 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0
DSL: Training log buffer capability is not enabled
cisco1841#
Command Lookup only said that attenuation is high.
I did not find docs on the Internet about Vendor Id TSTC.
Anyone can tell me info about the parameters reported in "sh dsl interface
atm " ?
A capacity used of 24% means that the line is underutilised ?
What are a good range values for Attenuation, Noise-margin and capacity in down and upload ?
What is the mean of output-power and where is it measured ?
best regards
francesco
nedian123
Compare the modulation(DSL Mode:) of Cisco 1801 with Cisco 1841.
hope this works...
Note: rate it if it works.
Akhtar
