ADSL Problems
kunal-united
Sakhr#sh runn
Sakhr#sh running-config
Building configuration...
Current configuration : 2018 bytes
version 12.3
no service pad
hostname Sakhr
boot-start-marker
boot-end-marker
enable secret xxxx
ip audit notify log
ip audit po max-events 100
ip ssh break-string
no ftp-server write-enable
no scripting tcl init
no scripting tcl encdir
no crypto isakmp enable
interface Ethernet0
ip address 192.168.20.1 255.255.255.0 secondary
ip address 213.132.133.33 255.255.255.248
ip accounting output-packets
ip nat inside
ip tcp adjust-mss 1452
hold-queue 100 out
interface ATM0
no ip address
no atm ilmi-keepalive
pvc 0/33
encapsulation aal5snap
protocol ppp dialer
dialer pool-member 1
dsl operating-mode auto
interface FastEthernet1
no ip address
duplex auto
speed auto
interface FastEthernet2
no ip address
duplex auto
speed auto
interface FastEthernet3
no ip address
duplex auto
speed auto
interface FastEthernet4
no ip address
duplex auto
speed auto
interface Dialer0
mtu 1492
ip address 10.1.6.102 255.255.255.252
ip nat outside
encapsulation ppp
dialer pool 1
dialer idle-timeout 0
dialer-group 1
ip nat inside source list 10 interface Ethernet0 overload
ip nat inside source static 192.168.20.227 213.132.133.34 extendable
ip nat inside source static 192.168.20.146 213.132.133.35 extendable
ip classless
ip route 0.0.0.0 0.0.0.0 10.1.6.101
ip http server
no ip http secure-server
access-list 10 permit 192.168.20.0 0.0.0.255
dialer-list 1 protocol ip permit
control-plane
line con 0
no modem enable
transport preferred all
transport output all
line aux 0
line vty 0 4
login local
transport input all
scheduler max-task-time 5000
end
I can reach my ISP but cannot browse to the ouside world.
I configuring my DSL router ...but seems everything is ok ...but nothing working
I have checked ...even the configurations at ISP site ...and they are just perfectly fine ...something wrong at my end only
nethelper
Level 3
Level 3
the following statement in your configuration doesn´t look right:
Try and change that to:
ip nat inside source list 10 interface Dialer0 overload
Also, there is a secondary address on your Ethernet0 interface that appears to be a public IP, what is that used for ?
Sakhr#sh runn
version 12.3
no service pad
hostname Sakhr
boot-start-marker
boot-end-marker
enable secret 5 $1$Y/jP$/yi6/NGrMFQZ07KMO.C2n/
ip audit notify log
ip ssh break-string
interface Ethernet0
ip nat inside
hold-queue 100 out
interface ATM0
no ip address
pvc 0/33
protocol ppp dialer
no ip address
duplex auto
speed auto
no ip address
duplex auto
speed auto
no ip address
duplex auto
speed auto
no ip address
duplex auto
speed auto
interface Dialer0
mtu 1492
ip nat outside
encapsulation ppp
dialer pool 1
dialer-group 1
-->ip nat inside source list 10 interface Dialer0 overload
ip classless
ip http server
control-plane
line con 0
no modem enable
line aux 0
line vty 0 4
login local
transport input all
end
Nethelper
This statement is right coz the ethernet0 is configured with public ip addresses.
This statement is wrong ...coz the dialer is not configured with public ip addresses....How will I go the the internet???
ip address 192.168.20.1 255.255.255.0 secondary is the LAN ip's which is natted to the public ip address.
I have many router configuratons which work ...but this one is quite strange
I don´t understand your setup, is the DSL line a second line to a different provider ?
If your provider is connected to the Ethernet0 interface, try the following configuration:
Sakhr#sh runn
version 12.3
no service pad
hostname Sakhr
boot-start-marker
boot-end-marker
enable secret xxxx
ip audit notify log
ip ssh break-string
-->interface Loopback0
ip address 1.1.1.1 255.255.255.0
interface Ethernet0
-->ip nat outside
hold-queue 100 out
-->ip policy route-map ISP
interface ATM0
no ip address
pvc 0/33
protocol ppp dialer
no ip address
duplex auto
speed auto
no ip address
duplex auto
speed auto
no ip address
duplex auto
speed auto
no ip address
duplex auto
speed auto
interface Dialer0
mtu 1492
ip nat outside
encapsulation ppp
dialer pool 1
dialer-group 1
ip classless
-->ip route 0.0.0.0 0.0.0.0 Ethernet0
ip http server
-->route-map ISP permit 10
match ip address 10
set interface Loopback0
control-plane
line con 0
no modem enable
line aux 0
line vty 0 4
login local
transport input all
end
Nethelper
