Adsl PVI/CVI limitation
osamaokok
Hi,,
I'm trying to setup cisco 1801 router with adsl port to internet, I had contacted my ISP about the pvi/cvi setting and i get 100/100.
when i tried to implement the PVC 100/100 it is only accepts 0-31 for the PVI is there any way to get over theis issue, My ios ver is 12.4(15)T6.
Regards fo all
Giuseppe Larosa
Hello Osama,
try the following
atm vc-per-vp 256
to change the number of VCI per VP and see if it changes the allowed range of VPI
Hope to help
Giuseppe
Giuseppe Larosa
Hello Osama,
try the following
atm vc-per-vp 256
Hope to help
Giuseppe
