Advanced HSRP configuration
Ahmed Tarek
Level 3
Level 3
hello all,
i need your support for the next scenario
i have 2 routers and have 2 ISP providers, ISP A, ISP B , how to add HSRP for 2 ISP in my 2 routers ? i mean i already added ISP A configuration in my 2 routers but how to add second ISP B too, thanks in advance
5 Replies 5
can you share topology?
what you most likely need is HSRP interface tracking. Post the full running configs of both routers, and indicate which interfaces are connected to which ISP, and which interfaces are being used for HSRP.
Ahmed Tarek
Level 3
Level 3
thanks for your post experts!
i will try here type my explain my points :
i have 2 routers and have 2 ISP providers, ISP A, ISP B , i need to add HSRP configuration to both of them to support 2 ISP i have.
how are both routers connected ? As requested, post a diagram of your topology, as well as the full running configurations of both routers...
as others stated, what are you trying to achieve, there are different ways to do it if you are looking to Load-balance and Failover or split the load to use both ISP, why do you need HSRP ?
we need to understand more clear of the goal, simply adding HSRP may not get the outcome you thinking.
see HSRP Guide lines.
https://www.cisco.com/c/en/us/td/docs/ios-xml/ios/ipapp_fhrp/configuration/xe-3s/fhp-xe-3s-book/fhp-hsrp.html
BB
