advantages/disadvantages router with L3 switch module and separate router/switch implementation
ernesto.arista
What are the advantages/disadvantages router with L3 switch module vs. separate router/switch implementation? excluding costs, like WAN bandwidth limitations, CPU usage, etc....
Ruben Cocheno
Depends of the purpose but using a model Core/Distribution/Access are:
Core - Routing/MPLS/Capacity/WAN Modules
Distribution -  Segregate the L2 from L3 (Core)
Access - Capacity of switch ports
Tag me to follow up.
Please mark it as Helpful and/or Solution Accepted if that is the case. Thanks for making Engineering easy again.
Connect with me for more on Linkedin https://www.linkedin.com/in/rubencocheno/
