Advertising interface route into different VRFs
bhaskar038
I'm trying to configure VRFs for multiple providers and struck with the following. The router R1 is connected to Provider-1, Switch and Provider-2. BGP is running between provider and R1.
Provider-1 is in VRF-1 and Provider-2 is in VRF-2. But, the f0/0 is in global routing table. I would like to advertise the f0/0 subnet to all the provider VRFs. I tried network XXXX mask xxxx. But, still not advertising as the subnet is not in routing table.Can someone help me this?
19 Replies 19
Julio E. Moisa
You could use the command import <RT> or import map.
This link could be useful
http://packetlife.net/blog/2010/mar/29/inter-vrf-routing-vrf-lite/
Is possible share the config?
>> Marcar como útil o contestado, si la respuesta resolvió la duda, esto ayuda a futuras consultas de otros miembros de la comunidad. <<
Julio,
Thanks for the response. Will review the blog and get back to you
You are welcome,
Hello
Basically youll could also to tell each vrf to check the global rib table staticlly for that subnet
Example:
ip Route vrf A x.x.x.x y.y.y.y fa0/0 global
ip Route vrf B x.x.x.x y.y.y.y fa0/0 global
as julio suggested and if applicable please post your configuration  so it can be reviewed by the forum
Kind Regards
Paul
Thanks Paul for the response. The following is config. I tried the static routes and unfortunately, it did not work.
ASR(config)#$f Windstream 1.1.1.0 255.255.255.0 fastEthernet 0/0
% For VPN routes, must specify a next hop IP address if not a point-to-point interface
Building configuration...
Current configuration : 2108 bytes
version 12.4
hostname ASR
boot-start-marker
boot-end-marker
no aaa new-model
memory-size iomem 5
no ip icmp rate-limit unreachable
ip cef
ip vrf Level-3
rd 300:10
ip vrf Windstream
description Windstream VRF
rd 200:10
import ipv4 unicast map Global-to-VRF
ip vrf Winstream
ip vrf forwarding
no ip domain lookup
ip auth-proxy max-nodata-conns 3
ip admission max-nodata-conns 3
ip tcp synwait-time 5
interface FastEthernet0/0
ip address 1.1.1.2 255.255.255.0
duplex auto
speed auto
interface FastEthernet0/1
ip vrf forwarding Windstream
ip address 192.168.100.2 255.255.255.0
duplex auto
speed auto
interface Serial1/0
no ip address
shutdown
serial restart-delay 0
interface Serial1/1
no ip address
shutdown
interface Serial1/2
no ip address
shutdown
interface Serial1/3
no ip address
shutdown
interface FastEthernet2/0
ip vrf forwarding Level-3
ip address 192.168.200.2 255.255.255.0
duplex auto
speed auto
router bgp 100
no synchronization
bgp log-neighbor-changes
no auto-summary
address-family ipv4 vrf Windstream
  redistribute connected
  neighbor 192.168.100.1 remote-as 200
  neighbor 192.168.100.1 activate
  no synchronization
  network 1.1.1.0 mask 255.255.255.0
exit-address-family
address-family ipv4 vrf Level-3
  neighbor 192.168.200.1 remote-as 300
  neighbor 192.168.200.1 activate
  no synchronization
exit-address-family
ip forward-protocol nd
no ip http server
no ip http secure-server
access-list 10 permit 1.1.1.0 0.0.0.255
no cdp log mismatch duplex
route-map Global-to-VRF permit 10
match ip address 10
control-plane
line con 0
exec-timeout 0 0
privilege level 15
logging synchronous
line aux 0
exec-timeout 0 0
privilege level 15
logging synchronous
line vty 0 4
login
end
Hello
Apologies i have misunderstood I see now you have routing protocol running , have you tried applying it to one vrf and route-leaking to another or as stated by others route leak via route-map
Kind Regards
Paul
Paul,
That interface should be advertised over all the VRFs
in addition to the other posts, the below should leak network 192.168.1.0/24 into both VRFs (AS numbers are arbitrary, obviously):
ip vrf WINDSTREAM
rd 1:1
import ipv4 unicast map GRT_TO_VRF
ip vrf LEVEL3
rd 2:2
ip dhcp excluded-address 192.168.1.1
ip dhcp pool LAN
network 192.168.1.0 255.255.255.0
default-router 192.168.1.1
interface Loopback1
ip address 1.1.1.1 255.255.255.255
description LAN
duplex auto
speed auto
media-type rj45
ip vrf forwarding WINDSTREAM
ip address 10.10.10.1 255.255.255.0
duplex auto
speed auto
media-type rj45
interface FasttEthernet0/2
ip vrf forwarding LEVEL3
ip address 20.20.20.1 255.255.255.0
duplex auto
speed auto
media-type rj45
router bgp 65000
bgp router-id 1.1.1.1
redistribute connected route-map GRT_TO_VRF
neighbor 10.10.10.2 remote-as 65001
neighbor 20.20.20.2 remote-as 65002
address-family ipv4 vrf WINDSTREAM
neighbor 10.10.10.2 activate
exit-address-family
address-family ipv4 vrf LEVEL3
neighbor 20.20.20.2 activate
exit-address-family
ip prefix-list GRT seq 5 permit 192.168.1.0/24
route-map GRT_TO_VRF permit 10
match ip address prefix-list GRT
Georg,
Thanks for the response. Tried the exact config. But, did not work. Please refer my config and let me know if I'm missing any
Could you please explain the reason behind configuring BGP neighborship in both ipv4 and vpn address families?
try the exact config below:
ip vrf Level-3
description Level-3 VRF
rd 300:10
ip vrf Windstream
rd 200:10
duplex auto
speed auto
duplex auto
speed auto
duplex auto
speed auto
router bgp 100
no synchronization
no auto-summary
redistribute connected route-map Global-to-VRF
no synchronization
exit-address-family
no synchronization
exit-address-family
ip prefix-list GRT seq 5 permit 1.1.1.0/24
Thanks Georg for the config. I pasted the exact config. But still the route is not in routing table of ASR as shown below.
ASR#sh ip route vrf Windstream
Routing Table: Windstream
Codes: C - connected, S - static, R - RIP, M - mobile, B - BGP
       D - EIGRP, EX - EIGRP external, O - OSPF, IA - OSPF inter area
       N1 - OSPF NSSA external type 1, N2 - OSPF NSSA external type 2
       E1 - OSPF external type 1, E2 - OSPF external type 2
       i - IS-IS, su - IS-IS summary, L1 - IS-IS level-1, L2 - IS-IS level-2
       ia - IS-IS inter area, * - candidate default, U - per-user static route
       o - ODR, P - periodic downloaded static route
Gateway of last resort is not set
     10.0.0.0/24 is subnetted, 1 subnets
B       10.10.10.0 [20/0] via 192.168.100.1, 00:05:53
B    192.168.1.0/24 [20/0] via 192.168.100.1, 00:05:53
C    192.168.100.0/24 is directly connected, FastEthernet0/1
ASR#
hostname ASR
boot-start-marker
boot-end-marker
no aaa new-model
memory-size iomem 5
ip cef
ip vrf Level-3
rd 300:10
ip vrf Windstream
rd 200:10
no ip domain lookup
duplex auto
speed auto
duplex auto
speed auto
interface Serial1/0
no ip address
shutdown
interface Serial1/1
no ip address
shutdown
interface Serial1/2
no ip address
shutdown
interface Serial1/3
no ip address
shutdown
duplex auto
speed auto
router bgp 100
no synchronization
no auto-summary
  no synchronization
exit-address-family
  no synchronization
exit-address-family
no ip http server
Try and clear the routing table of the vrfs:
clear ip route vrf Windstream *
clear ip route vrf Level-3 *
What is the output of 'show ip route' (the global routing table) ?
Georg,
I tried clearing the route table for both VRFs. But, still nothing.
B       10.10.10.0 [20/0] via 192.168.100.1, 00:00:12
B    192.168.1.0/24 [20/0] via 192.168.100.1, 00:00:12
ASR#
ASR#
ASR#sh ip rou
ASR#sh ip route
     1.0.0.0/24 is subnetted, 1 subnets
C       1.1.1.0 is directly connected, FastEthernet0/0
Odd. I am doing this in GNS3 with 15.6 IOS routers. It could be platform/IOS related...what is the output of 'show version' ?
