Advertising IPv6 Routes Over IPv4 EBGP Peering
mustansirt
I am receiving route on each router but its showing inaccessible
"inaccessible"
Router-1
ipv6 unicast-routing
ipv6 cef
interface Loopback0
no ip address
ipv6 address 2001:101:1:1::1/128
interface FastEthernet0/0
ip address 172.16.1.1 255.255.255.252
duplex half
ipv6 address 2001::1/64
ipv6 enable
router bgp 101
bgp router-id 1.1.1.1
bgp log-neighbor-changes
neighbor 172.16.1.2 remote-as 102
address-family ipv4
  no neighbor 172.16.1.2 activate
exit-address-family
address-family ipv6
  network 2001:101:1:1::1/128
  neighbor 172.16.1.2 route-map SET_IPV6_NEXT_HOP_OUT out
exit-address-family
route-map SET_IPV6_NEXT_HOP_OUT permit 10
set ipv6 next-hop 2001::1
Router 2
ipv6 cef
interface Loopback0
no ip address
ipv6 address 2001:102:2:2::2/128
ip address 172.16.1.2 255.255.255.252
duplex half
ipv6 address 2001::2/64
ipv6 enable
router bgp 102
bgp router-id 2.2.2.2
neighbor 172.16.1.1 remote-as 101
address-family ipv4
  no neighbor 172.16.1.1 activate
exit-address-family
address-family ipv6
  network 2001:102:2:2::2/128
  neighbor 172.16.1.1 route-map SET_IPV6_NEXT_HOP_OUT out
exit-address-family
set ipv6 next-hop 2001::2
router -1 o/p
R1#sh bgp ipv6 unicast
BGP table version is 2, local router ID is 1.1.1.1
Status codes: s suppressed, d damped, h history, * valid, > best, i - internal,
              r RIB-failure, S Stale, m multipath, b backup-path, x best-external, f RT-Filter
Origin codes: i - IGP, e - EGP, ? - incomplete
   Network          Next Hop            Metric LocPrf Weight Path
*> 2001:101:1:1::1/128
                    ::                       0         32768 i
*  2001:102:2:2::2/128
                    2001::2                  0             0 102 i
R1#sh bgp ipv6 unicast 2001:102:2:2::2/128
BGP routing table entry for 2001:102:2:2::2/128, version 0
Paths: (1 available, no best path)
  Not advertised to any peer
  102
    2001::2 (FE80::C802:B8FF:FE46:0) (inaccessible) from 172.16.1.2 (2.2.2.2)
      Origin IGP, metric 0, localpref 100, valid, external
router 2
R2#sh bgp ipv6 unicast
BGP table version is 3, local router ID is 2.2.2.2
*  2001:101:1:1::1/128
                    2001::1                  0             0 101 i
*> 2001:102:2:2::2/128
                    ::                       0         32768 i
R2#sh bgp ipv6 unicast  2001:101:1:1::1/128
BGP routing table entry for 2001:101:1:1::1/128, version 0
  101
    2001::1 (FE80::C801:B8FF:FE45:0) (inaccessible) from 172.16.1.1 (1.1.1.1)
Because of the IPv4 to IPv6 next hop conversion, older IOS software versions considered the next hop not to be directly connected and required either "ebgp multihop" or the "disable-connected-check" knob to be configured.
This is not the case with more recent IOS software versions.
As a side note, it is generally considered best practice to use an IPv6 BGP session (IPv6 transport) to carry IPv6 updates. This way if the ipv6 dataplane fails (ACL, software bug, etc) the IPv6 updates will stop being conveyed.
Harold Ritter
Sr Technical Leader
CCIE 4168 (R&S, SP)
harold@cisco.com
México móvil: +52 1 55 8312 4915
Cisco México
Paseo de la Reforma 222
Piso 19
Cuauhtémoc, Juárez
Ciudad de México, 06600
México
5 Replies 5
bersoare
I just loaded the config you posted on 2 7200 (gns3) running IOS 15.2 and it worked fine:
R1#sh ipv6 route
IPv6 Routing Table - default - 5 entries
Codes: C - Connected, L - Local, S - Static, U - Per-user Static route
B - BGP, R - RIP, H - NHRP, I1 - ISIS L1
I2 - ISIS L2, IA - ISIS interarea, IS - ISIS summary, D - EIGRP
EX - EIGRP external, ND - ND Default, NDp - ND Prefix, DCE - Destination
NDr - Redirect, O - OSPF Intra, OI - OSPF Inter, OE1 - OSPF ext 1
OE2 - OSPF ext 2, ON1 - OSPF NSSA ext 1, ON2 - OSPF NSSA ext 2, l - LISP
C 2001::/64 [0/0]
via FastEthernet0/0, directly connected
L 2001::1/128 [0/0]
via FastEthernet0/0, receive
LC 2001:101:1:1::1/128 [0/0]
via Loopback0, receive
B 2001:102:2:2::2/128 [20/0]
via FE80::C802:2AFF:FE3C:8, FastEthernet0/0
L FF00::/8 [0/0]
via Null0, receive
R1#sh ip bgp ipv6 u 2001:102:2:2::2/128
BGP routing table entry for 2001:102:2:2::2/128, version 3
Paths: (1 available, best #1, table default)
Refresh Epoch 1
102
2001::2 (FE80::C802:2AFF:FE3C:8) from 172.16.1.2 (2.2.2.2)
Origin IGP, metric 0, localpref 100, valid, external, best
rx pathid: 0, tx pathid: 0x0
R1#
You might have hitted a bug in the IOS you are running.
You should verify if the router who is receiving the inaccessible prefix knows the point to point networks into the BGP table. You could try advertising them into BGP.
>> Marcar como útil o contestado, si la respuesta resolvió la duda, esto ayuda a futuras consultas de otros miembros de la comunidad. <<
Actually after adding ebgp multihop under BGP ipv6 address-family it worked, found this solution on the Cisco forum itself.
But don't understand the need to do this.
Please let me check the configuration again.
Regards.
Harold Ritter
Sr Technical Leader
CCIE 4168 (R&S, SP)
harold@cisco.com
Cisco México
Piso 19
Cuauhtémoc, Juárez
México
