AIM-ATM-4T1 - installation and configuration (IMA config)
ppierre135
Hello all,
I'm trying to configure 4 Data T1's from AT&T. I've purchased the AIM-ATM-4T1 Bundle, in AIM 0 on the board and installed the T1 controllers in WIC 0 and 1. in config mode i cannot seem to apply the "mode atm" in the controller sub-config? i've upgraded to the appropriate image?
wanr2-60mad-4n(config)#controller T1 0/0/0
wanr2-60mad-4n(config-controller)#mode ?
cas Configure CAS (Channel Associated Signal) mode
ccs Configure CCS (Common Channel Signal) mode
wanr2-60mad-4n#sh ver
Load for five secs: 0%/0%; one minute: 0%; five minutes: 0%
Time source is NTP, 12:46:34.842 EST Fri Dec 7 2007
Cisco IOS Software, 2800 Software (C2800NM-ADVENTERPRISEK9-M), Version 12.4(11)T, RELEASE SOFTWARE (fc2)
Copyright (c) 1986-2006 by Cisco Systems, Inc.
Compiled Sat 18-Nov-06 17:16 by prod_rel_team
ROM: System Bootstrap, Version 12.4(13r)T, RELEASE SOFTWARE (fc1)
wanr2-60mad-4n uptime is 1 hour, 4 minutes
System returned to ROM by reload at 11:40:46 EST Fri Dec 7 2007
System restarted at 11:42:11 EST Fri Dec 7 2007
System image file is "flash:c2800nm-adventerprisek9-mz.124-11.T.bin"
Cisco 2821 (revision 53.51) with 249856K/12288K bytes of memory.
Processor board ID FHK1140F3U8
2 Gigabit Ethernet interfaces
4 Channelized T1/PRI ports
1 Virtual Private Network (VPN) Module
DRAM configuration is 64 bits wide with parity enabled.
239K bytes of non-volatile configuration memory.
62720K bytes of ATA CompactFlash (Read/Write)
wanr2-60mad-4n#sh diag
Slot 0:
C2821 Motherboard with 2GE and integrated VPN Port adapter, 2 ports
Port adapter is analyzed
Port adapter insertion time unknown
Onboard VPN : v2.3.3
EEPROM contents at hardware discovery:
PCB Serial Number : FOC113748D8
Hardware Revision : 1.0
Top Assy. Part Number : 800-26921-03
Board Revision : A0
Deviation Number : 0
Fab Version : 03
RMA Test History : 00
RMA Number : 0-0-0-0
RMA History : 00
Processor type : 87
Hardware date code : 20070918
Chassis Serial Number : FHK1140F3U8
Chassis MAC Address : 001d.a106.6d88
MAC Address block size : 32
CLEI Code : COM7M00ARA
Product (FRU) Number : CISCO2821
Part Number : 73-8853-05
Version Identifier : V04
WIC Slot 0:
T1 (2 port) Multi-Flex Trunk WAN daughter card
Hardware revision 1.0 Board revision F0
Serial number 32419598 Part number 800-04477-03
FRU Part Number VWIC-2MFT-T1=
Test history 0x0 RMA number 00-00-00
WIC Slot 1:
Serial number 32419772 Part number 800-04477-03
while there seems to be a lot of information on this type of scenario, none specifies the 2800 series..mostly 2600 and 3600's? Anybody?
chris_tan
You are purchased a bundle, which should come with 2 VWIC2 and 1 AIM-ATM (CISCO High Performance ATM Advanced Integration Module), i believe your vendor did not install AIM-ATM or the AIM-ATM module is faulty. Please check with your vendor.
Hope it help. :-)
Rgds.
Christopher
