AIM-ATM to NM-ATM module
Corey OBrien
we have been using the NM-ATM mods without issue but they are now discontinued. I am trying to use an AIM-ATM mod with at VWIC-2MFT-T1 card and connect to a NM-ATM interface on the other side. the aim-atm side clears with no alarm but the nm-atm side still alarms. wondering if there is a compatibility issue?
sbilgi
Level 5
Level 5
To further look into this issue, can you send me a brief overview of your network setup?. Or, it would be even better if you can send me your network topological diagram. Because, with some clear information, I will be able to guide you confidently.
Also, send me the configurations you have made in all your devices. Example is a show tech output.
