All routing between LAN and WAN works, except Router to WAN
tripnosis
I am fairly new to Cisco IOS, yet I've managed to get it up and running on a Cisco 1841 to act as a router and firewall between WAN and LAN.  Everything works *except* I am unable to ping or make any other connection from the router itself to the WAN.  It will ping or telnet to the LAN, all LAN to WAN traffic is functioning properly, NAT is setup and functioning, WAN to LAN and inbound firewall is working, yet I still cannot ping or telnet from the IOS interface to anything on the WAN side (I've tried using different source addresses)
I am hoping there is something obvious that I overlooked, perhaps IPS is blocking the traffic?  Do I need a specific route entry for the local device?  I can post entire config if necessary, but would rather not if there is an obvious solution.
this is due to CBAC no inspecting traffic generated by router. if your IOS is 12.3(14)T or higher then you can do this:
ip inspect name SDM_LOW  icmp router-traffic
ip inspect name SDM_LOW  tcp  router-traffic
ip inspect name SDM_LOW  udp router-traffic
Regards.
Alain.
10 Replies 10
Vaibhava Varma
Level 4
Level 4
Hi Andrew
The WAN Side which we are talking about is managed by You or ISP.
If its in the ISP control there is a fair probability of ISP Blocking ICMP and restricting telnet access to their devices from the Customer side which happens mostly.
Hope this helps you on this query.
Varma
The cisco I am on is not managed by the ISP.  I can ping the gateway (managed by the ISP) and other things (google, yahoo, etc) from the LAN machines, just not from the router directly. I am able to make any connection from inside the LAN to the router, or from the LAN and out tru the WAN interface to the world.  If I am logged into the router, I can not connect from the router to the outside world, but it will connect to machines inside the LAN.
(LAN) 192.168.5.x  -> 1841 -> WAN   works.
WAN -> 1841 -> LAN works.
1841 -> LAN works
1841 -> WAN does not work.
In most cases I would not mind this, however, I need to setup a VPN to a remote site and the cisco can not connect outbound to the remote VPN router (or anything else).
Hi Andrew
I am still bit unclear on the actual network setup in question here ?
Can you please clarifiy that the WAN here we are referring to is another Cisco Router after 1841 managed by you. For the LAN gateway is 1841 and then we are using routing between 1841 and WAN further. Where is the NAT happening in this case ? Is it on the WAN router managed by you . Is the link between 1841 to WAN a private subnet ? Is that allowed in the NAT Policy on the WAN router ?
Varma
Yes, the WAN connection is to another Cisco managed by the ISP (which is then connected to a fiber network, all managed by the ISP).  Their cisco passes all the real IP traffic to my 1841, which acts as the Router/Firewall between the WAN and LAN.  They control the .1 gateway for the classC, my 1841 is setup as .2
LAN (192.168.5.x) --> Cisco 1841 (firewall/nat/etc) -> WAN (4.3.2.x) Cisco 2800 (ISP controlled) --> Fiber/MetroE
Gateway:  4.3.2.1
Cisco 1841 WAN:  4.3.2.2
Cisco 1841 LAN:  192.168.5.1
Inside LAN:  192.168.5.x
I am stumped because all traffic from LAN to WAN and WAN to LAN (including al NAT, ACL, etc) works as intended except for the 1841 being unable to make a connection from itself out thru the WAN.  It will connect from itself to the LAN, ie 'ping 192.168.5.10' works, 'ping 4.3.2.1' does not. (nor does any other outgoing connection that originates from the local 1841)
So you say you can ping the ISP address from the LAN but not from router WAN address?
Can you post  your sanitized running-config.
Regards.
Alain.
Exactly.  I can ping from LAN to WAN, router to LAN, but not router to WAN.
post your config.
Alain.
Some settings are X'd out, relevant config should all be there.
! Last configuration change at 12:24:32 EST Sun Oct 23 2011 by admin
! NVRAM config last updated at 12:42:39 EST Sun Oct 23 2011
version 12.4
service sequence-numbers
hostname router
boot-start-marker
boot-end-marker
logging buffered 51200 warnings
enable secret 5 XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX
no aaa new-model
clock timezone EST -5
ip cef
ip domain name XXXXXXXXXXXXXXXXXX.com
ip name-server XXXXXXXXXXX
ip inspect name SDM_LOW cuseeme
ip inspect name SDM_LOW dns
ip inspect name SDM_LOW ftp
ip inspect name SDM_LOW h323
ip inspect name SDM_LOW https
ip inspect name SDM_LOW imap
ip inspect name SDM_LOW pop3
ip inspect name SDM_LOW netshow
ip inspect name SDM_LOW rcmd
ip inspect name SDM_LOW realaudio
ip inspect name SDM_LOW rtsp
ip inspect name SDM_LOW esmtp
ip inspect name SDM_LOW sqlnet
ip inspect name SDM_LOW streamworks
ip inspect name SDM_LOW tftp
ip inspect name SDM_LOW vdolive
ip inspect name SDM_LOW pop3s
ip inspect name SDM_LOW imaps
ip auth-proxy max-nodata-conns 3
ip admission max-nodata-conns 3
ip ips sdf location flash://128MB.sdf autosave
ip ips notify SDEE
ip ips name sdm_ips_rule
crypto pki trustpoint TP-self-signed-720109512
enrollment selfsigned
subject-name cn=IOS-Self-Signed-Certificate-720109512
revocation-check none
rsakeypair TP-self-signed-720109512
crypto pki certificate chain TP-self-signed-720109512
certificate self-signed 01
  XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX
  quit
username admin privilege 15 secret 5 XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX
controller T1 0/0/0
framing esf
linecode b8zs
controller T1 0/1/0
framing esf
linecode b8zs
interface FastEthernet0/0
description $ETH-LAN$$ETH-SW-LAUNCH$$INTF-INFO-FE 0$$ES_LAN$$FW_INSIDE$
ip address 192.168.5.1 255.255.255.0
ip access-group sdm_fastethernet0/0_in in
ip nat inside
ip virtual-reassembly
duplex auto
speed auto
interface FastEthernet0/1
description $ETH-WAN$$FW_OUTSIDE$
ip address 66.83.7.2 255.255.255.0
ip access-group sdm_fastethernet0/1_in in
ip verify unicast reverse-path
ip nat outside
ip inspect SDM_LOW out
ip ips sdm_ips_rule in
duplex auto
speed auto
no ip classless
no ip forward-protocol nd
ip route 0.0.0.0 0.0.0.0 66.83.7.1
ip http server
ip http authentication local
ip http secure-server
ip http timeout-policy idle 60 life 86400 requests 10000
ip nat pool WAN-MAIN 66.83.7.241 66.83.7.254 prefix-length 24
ip nat inside source list 1 pool WAN-MAIN
ip nat inside source static 192.168.5.11 66.83.7.11
ip nat inside source static 192.168.5.12 66.83.7.12
ip nat inside source static 192.168.5.13 66.83.7.13
ip nat inside source static 192.168.5.15 66.83.7.15
ip nat inside source static 192.168.5.32 66.83.7.32
ip nat inside source static 192.168.5.221 66.83.7.221
ip nat inside source static 192.168.5.222 66.83.7.222
ip access-list extended sdm_fastethernet0/0_in
remark SDM_ACL Category=1
remark Permit all outbound traffic
permit ip any any
ip access-list extended sdm_fastethernet0/1_in
permit tcp any host XXXXXXXXXX eq XXXX
deny   ip any any
access-list 1 permit 192.168.5.0 0.0.0.255
disable-eadi
control-plane
line con 0
password XXXXXXXXX
login
line aux 0
line vty 0 4
privilege level 15
password XXXXXXXXX
login
transport input telnet ssh
line vty 5 15
privilege level 15
password XXXXXXXXX
login
scheduler allocate 20000 1000
end
Regards.
Alain.
Thank Alain,  That did it.  I suspected it may have been related to SDM but never would have found that in a million years.
thanks again.
