Allow Access from DMZ to Inside
junshah22
Please find attached configuration of my ASA, I am trying to give access to tcp ports 50,000 to 60,000 from DMZ to Inside interface
I am using default security levels with no nat.
Please advise
Bryan Lee
Junaid,
For Internet Access From DMZ use below command
nat (dmz) 1 192.168.1.0 255.255.255.0
For DMZ To inside you will have to configure an identity nat and acl on dmz interface for allowing traffic from dmz to inside
For example if you want to access 192.168.20.20 machine from DMZ zone use below commands
static(inside,dmz) 192.168.20.20 192.168.20.20 netmask 255.255.255.255
and acl
access-list dmz extended permit ip any host 192.168.20.20
access-group dmz in interface dmz
This will allow you to reach inside network host from dmz zone.
second thing if you want to access DMZ network from Inside
global (dmz) 1 192.168.1.200-192.168.1.225 (ip pool from DMZ subnet)
This will allow you to reach dmz network from inside.
Thanks,'
Amod
You need to add the below static nat inorder to get that DMZ to Inside.
Make sure the below statement with your real IP range.
static (inside,dmz) 192.168.1.0 192.168.20.0 netmask 255.255.255.255
Please rate the helpfull posts.
Naidu.
