Allow exceeded MSS on VPN router????
billy_maclin
Branch office has 881 VPN router. Services that ignore MSS in packets don't work. Adjusting MSS has no effect since the services are ignoring that setting. Example: www.google.com works fine, but some Yahoo sites don't.
Found a workaround for exceeded MSS for PIX and ASA (link below), but can't find anything for VPN routers.
http://www.cisco.com/en/US/customer/products/hw/vpndevc/ps2030/products_tech_note09186a00804c8b9f.shtml
MS,
Let me apologize for my earlier response. I was not applying "ip tcp mss-adjust" correctly. I still had the value too high and ended up lowering it to 1300. I also needed to enable "ip tcp path-mtu-discovery" and "tunnel path-mtu-discovery", at both ends of the connection.
After adding everything and applying MSS adjust correctly, my problem has been resolved.
Again, sincerest apologies.
Best regards,
BMac
mvsheik123
Level 7
Level 7
Check whether the attached pdf helps with this.
Thx
MS
No, adjusting MSS value has no effect because the receiving end is ignoring this value in packets. That's why some services work and others don't.
Thanks for trying.
MS,
Best regards,
BMac
