allow internet traffic to a single workstation
jazzybrakes
I have a ISP wireless router which connects to my lan. The gateway/dhcp server is connected directly to the isp via fa 0/1. Gateway fa 0/0 is connected to another router "local_router" and is a client of dhcp server. Everything is up and running and working fine but my extended access list wont work as intended.
GATEWAY-ROUTER#
GATEWAY-ROUTER#sh run
Building configuration...
Current configuration : 1259 bytes
version 12.4
hostname GATEWAY-ROUTER
boot-start-marker
boot-end-marker
enable secret 5 $1$XN.E$ioR/54rQq83qvcj244SJU0
no aaa new-model
ip cef
no ip dhcp use vrf connected
ip dhcp excluded-address 192.168.1.1 192.168.1.10
ip dhcp pool NET-192-168-1
network 192.168.1.0 255.255.255.224
dns-server 8.8.8.8
default-router 192.168.1.1
interface FastEthernet0/0
ip address 10.0.0.1 255.255.255.252
ip nat inside
duplex auto
speed auto
interface FastEthernet0/1
ip address dhcp
ip nat outside
duplex auto
speed auto
interface Serial0/0/0
no ip address
shutdown
router ospf 1
log-adjacency-changes
network 10.0.0.0 0.0.0.3 area 0
network 192.168.2.0 0.0.0.255 area 0
ip forward-protocol nd
ip route 0.0.0.0 0.0.0.0 192.168.2.1
no ip http server
no ip http secure-server
ip nat inside source list 1 interface FastEthernet0/1 overload
access-list 1 permit 192.168.1.0 0.0.0.31
Hi there,
I would make the following changes:
!GATEWAY-ROUTER
no ip route 0.0.0.0 0.0.0.0 192.168.2.1
ip route 0.0.0.0 0.0.0.0 dhcp
router ospf 1
  default-information originate
!LOCAL-ROUTER
access-list 101 permit tcp 192.168.1.0 0.0.0.31 any eq www
access-list 101 permit tcp 192.168.1.0 0.0.0.31 any eq 443
access-list 101 permit tcp 192.168.1.0 0.0.0.31 any eq 53
access-list 101 permit udp 192.168.1.0 0.0.0.31 any eq 53
I think crucially with the ACL the modified version above permits the entire subnet specified in the DHCP scope. Plus it also permits TCP/UDP traffic to the bare minimum of ports required for web browsing.
cheers,
Seb.
5 Replies 5
jazzybrakes
Below is the Local_router config file
Local-Router#
Local-Router#
Local-Router#sh run
Current configuration : 1038 bytes
version 12.4
hostname Local-Router
boot-start-marker
boot-end-marker
logging message-counter syslog
no aaa new-model
ip source-route
ip cef
archive
log config
hidekeys
ip address 10.0.0.2 255.255.255.252
duplex auto
speed auto
ip address 192.168.1.1 255.255.255.224
ip access-group 101 in
ip helper-address 10.0.0.1
duplex auto
speed auto
router ospf 1
network 192.168.1.0 0.0.0.31 area 0
no ip http server
access-list 101 permit tcp host 192.168.1.13 any eq www
control-plane
banner motd ^C Inside Router configuration ^C
line con 0
password cisco
login
line aux 0
line vty 0 4
password cisco
login
transport input telnet
scheduler allocate 20000 1000
end
Hi there,
!GATEWAY-ROUTER
router ospf 1
!LOCAL-ROUTER
cheers,
Seb.
you are correct i was only blocking port 80. thank you for your help
Hello
If it’s a static port address translation that you are trying to achieve so external hosts can reach that intrernal host on port 80 via your public ip address then this needs to be applied on the Gateway router not the Local router accompanied with a PAT statement?
Please see attached file.
Kind Regards
Paul
Thank you for your assistance. i am using PAT and not static nat. I have an network with 6 workstation was trying to restrict/block only 1 from accessing the internet. Its sorted out not i was not blocking all the ports thats why thank you
