Allow ping from inside to ASA and traceroute
jschaeffer1
I have an ASA 5508 and I'm trying to allow hosts on the inside network to ping the ASA outside interface. From my understanding requests from a higher security level to a lower should be implicitly allowed, however it looks like all icmp echo requests are being dropped at the inside interface. Note that I can ping past the outside interface. Below is my network layout:
  When I try to ping the outside interface from an inside network it fails:
user@server02:~$ ip --brief -4 addr show bond-mgmt
bond-mgmt        UP             10.2.28.100/22
user@server02:~$ ping -c 4 10.2.1.1
PING 10.2.1.1 (10.2.1.1) 56(84) bytes of data.
64 bytes from 10.2.1.1: icmp_seq=1 ttl=254 time=0.375 ms
64 bytes from 10.2.1.1: icmp_seq=2 ttl=254 time=0.378 ms
64 bytes from 10.2.1.1: icmp_seq=3 ttl=254 time=0.357 ms
64 bytes from 10.2.1.1: icmp_seq=4 ttl=254 time=0.398 ms
--- 10.2.1.1 ping statistics ---
4 packets transmitted, 4 received, 0% packet loss, time 3056ms
rtt min/avg/max/mdev = 0.357/0.377/0.398/0.014 ms
user@server02:~$ ping -c 4 203.0.113.5
PING 203.0.113.5 (203.0.113.5) 56(84) bytes of data.
--- 203.0.113.5 ping statistics ---
4 packets transmitted, 0 received, 100% packet loss, time 3076ms
user@server02:~$ ping -c 4 203.0.113.1
PING 203.0.113.1 (203.0.113.1) 56(84) bytes of data.
64 bytes from 203.0.113.1: icmp_seq=1 ttl=63 time=0.637 ms
64 bytes from 203.0.113.1: icmp_seq=2 ttl=63 time=0.614 ms
64 bytes from 203.0.113.1: icmp_seq=3 ttl=63 time=0.609 ms
64 bytes from 203.0.113.1: icmp_seq=4 ttl=63 time=1.55 ms
--- 203.0.113.1 ping statistics ---
4 packets transmitted, 4 received, 0% packet loss, time 3048ms
rtt min/avg/max/mdev = 0.609/0.854/1.558/0.407 ms
Here is my config on the ASA:
ASA# show running-config
ASA Version 9.8(2)
interface GigabitEthernet1/1
 channel-group 1 mode active
 no nameif
 no security-level
 no ip address
interface GigabitEthernet1/2
 no nameif
 no security-level
 no ip address
interface GigabitEthernet1/3
 channel-group 2 mode active
 no nameif
 no security-level
 no ip address
interface GigabitEthernet1/4
 no nameif
 no security-level
 no ip address
interface Port-channel1
 lacp max-bundle 8
 nameif outside
 security-level 0
 ip address 203.0.113.5 255.255.255.248
 ipv6 address 2001:db8:1::4/64
 ipv6 enable
interface Port-channel2
 lacp max-bundle 8
 nameif inside
 security-level 100
 ip address 10.2.1.1 255.255.255.0
 ipv6 address 2001:db8:2::1/64
 ipv6 enable
access-list outside_ingress extended permit ip any 203.0.113.0 255.255.255.0
access-list outside_ingress extended permit icmp any 198.41.100.0 255.255.255.248
access-list outside_ingress extended permit tcp any host 203.0.113.84 eq imap4
access-list outside_ingress extended permit tcp any host 203.0.113.85 eq 587
access-list outside_ingress extended permit tcp any host 203.0.113.85 eq smtp
access-list outside_ingress extended permit ip any 2001:db8:2::/48
access-list outside_ingress extended permit icmp6 any 2001:db8:1::/64
access-list outside_ingress extended permit tcp any host 2001:db8:2::1 eq imap4
access-list outside_ingress extended permit tcp any host 2001:db8:2::2 eq 587
access-list outside_ingress extended permit tcp any host 2001:db8:2::3 eq smtp
pager lines 24
logging buffered informational
logging asdm informational
mtu outside 1500
mtu inside 1500
no failover
no monitor-interface service-module
icmp unreachable rate-limit 1 burst-size 1
no asdm history enable
arp timeout 14400
no arp permit-nonconnected
arp rate-limit 16384
access-group outside_ingress in interface outside
ipv6 route outside ::/0 2001:db8:1::1
ipv6 route inside 2001:db8:2::/48 2001:db8:2:1::1
route outside 0.0.0.0 0.0.0.0 203.0.113.1 1
route inside 10.2.0.0 255.255.0.0 10.2.1.2 1
route inside 203.0.113.0 255.255.255.0 10.2.1.2 1
route inside 192.168.4.0 255.255.255.0 10.2.1.2 1
timeout xlate 3:00:00
timeout pat-xlate 0:00:30
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 sctp 0:02:00 icmp 0:00:02
timeout sunrpc 0:10:00 h323 0:05:00 h225 1:00:00 mgcp 0:05:00 mgcp-pat 0:05:00
timeout sip 0:30:00 sip_media 0:02:00 sip-invite 0:03:00 sip-disconnect 0:02:00
timeout sip-provisional-media 0:02:00 uauth 0:05:00 absolute
timeout tcp-proxy-reassembly 0:01:00
timeout floating-conn 0:00:00
timeout conn-holddown 0:00:15
timeout igp stale-route 0:01:10
class-map inspection_default
 match default-inspection-traffic
policy-map type inspect dns preset_dns_map
 parameters
  message-length maximum client auto
  message-length maximum 512
  no tcp-inspection
policy-map global_policy
 class inspection_default
  inspect ftp
  inspect h323 h225
  inspect h323 ras
  inspect rsh
  inspect rtsp
  inspect esmtp
  inspect sqlnet
  inspect skinny
  inspect sunrpc
  inspect xdmcp
  inspect sip
  inspect netbios
  inspect tftp
  inspect ip-options
  inspect icmp
service-policy global_policy global
: end
I'd also like to allow traceroute from inside my network, but this seems to be failing for IPv4:
user@server01:~$ traceroute 8.8.8.8
traceroute to 8.8.8.8 (8.8.8.8), 64 hops max
  1   10.2.24.1  1.145ms  2.477ms  2.198ms
  2   *  *  *
  3   *  *  *
  4   *  *  *
  5   *  *  *
  6   *  *  *
  7   *  *  *
  8   *  *  *
  9   *  *  *
 10   *  *  *
 11   *  *  *
 12   *  *  *
 13   *  *  *
 14   *  *  *
 15   *  *  *
 16   *  *  *
 17   *  *  *
 18   *  *  *
 19   *  *  *
 20   *  *  *
 21   *  *  *
 22   *  *  *
 23   *  *  *
 24   *  *  *
That is not possible (by design).
"The ASA only responds to ICMP traffic sent to the interface that traffic comes in on; you cannot send ICMP traffic through an interface to a far interface"
Reference:-
https://www.cisco.com/c/en/us/td/docs/security/asa/asa-command-reference/I-R/cmdref2/i1.html
Reference:-
Good to know, thanks.
