01-11-2017 11:52 PM - edited 03-05-2019 07:49 AM
HI please let let me know the probable causes that BGP is not installing alternate path in its table while alternate path is available. Topology attached fyi and not getting alternate path at R4 .
01-12-2017 12:28 AM
are all ASs under your control ? Check if BGP Best External feature has not been enabled:
http://www.cisco.com/c/en/us/td/docs/ios-xml/ios/iproute_bgp/configuration/xe-3s/irg-xe-3s-book/bgp_best_external.html
01-12-2017 04:08 AM
01-12-2017 04:25 AM
I actually meant for you to check if the feature was enabled. Apparently that is not the case.
The fastest way for you to get your question answered is to post the configs of all routers so we can lab it.
01-12-2017 10:08 AM
Hello
This is due to bgp path selection criteria
R2 will see the short test path via R4 due those received prefixes having a shorter as path squence in it bgp table hence the routes from R4 will get installed in its rib
res
paul
01-12-2017 01:49 AM
Hello
When you say alternate path - can you elaborate, Do you mean an alternate bgp path towards R4 from ASN 10
Are you wanting to LB between EBGP peers?
res
Paul
01-12-2017 02:30 AM
