alternative solution
korbenda11as
what other solution I can do to use my frame relay switch router to remote other connected routers. I have two routers connected to this frame switch using back-to-back serial connector. My understanding is that frame switch is transparent to other routers. Are there any other configurations I can use to use my frame switch to telnet to other routers?
5 Replies 5
mohammedmahmoud
Level 11
Level 11
Hi Oliver,
Your understanding is correct. The only thing that can pop up to my mind, is a work around that i've used during my CCIE lab preparation, i was out of routers, and i needed to use the router acting as the FR Switch as a router in the scenario. Ok, all you need is a couple of serial interfaces on the FR Switch, connect them together (imagine that its another router connected to the FR Switch) and configure 2 new PVCs on the FR Switch with both your routers, and now you can access both routers from the router acting as the FR Switch.
BR,
Mohammed Mahmoud.
Are you trying to say, I will make a loop connection between two serial interfaces?
can you share me the configuration you used for that workaround? thanks...
hi,
Try this. It should work
FR
frame-relay switching
interface Serial1/0
no ip address
encapsulation frame-relay
serial restart_delay 0
frame-relay intf-type dce
frame-relay route 102 interface Serial1/1 201
interface Serial1/1
no ip address
frame-relay route 201 interface Serial1/0 102
R1
interface Serial1/0
no ip address
interface Serial1/0.102 point-to-point
ip address 172.16.12.1 255.255.255.0
frame-relay interface-dlci 102
R2
interface Serial1/0
no ip address
interface Serial1/0.201 point-to-point
ip address 172.16.12.2 255.255.255.0
frame-relay interface-dlci 201
HTH.
Cheers,
Nikhil E.
Hi Oliver,
Sorry for the late reply, i was checking the old threads and found your respond to my reply, anyway yes that was my opinion, below is how the configuration should look like:
interface serial2/1
description FRSW routed interface
no frame-relay inverse-arp
ip address 10.1.1.1 255.255.255.0
frame-relay map ip 1.1.1.2 102 broadcast
frame-relay map ip 1.1.1.3 103 broadcast
interface Serial2/2
description FR Switching port connected to the FRSW
no ip address
clock rate 64000
frame-relay route 102 interface Serial2/3 201
frame-relay route 103 interface Serial2/4 301
interface serial 2/3
description FR Switching port connected to R1
no ip address
clock rate 64000
frame-relay route 201 interface Serial2/2 102
frame-relay route 203 interface Serial2/4 302
interface serial 2/4
description FR Switching port connected to R2
no ip address
clock rate 64000
frame-relay route 301 interface Serial2/2 103
frame-relay route 302 interface Serial2/3 203
BR,
Mohammed Mahmoud.
Giuseppe Larosa
interesting question.
A FR switch is still a router and can do what you want if you use an additional DLCI that is not Frame Relay switched using the command frame-relay route
see the following from my lab:
interface Serial3/3
description verso c3745b-ser3/0
no ip address
frame-relay route 705 interface Serial3/2 507
frame-relay route 706 interface Serial3/5 607
interface Serial3/3.701 point-to-point
ip address 192.168.37.6 255.255.255.252
frame-relay interface-dlci 701
Of course on other interfaces the FR switch can be a PE router for example.
Hope to help
Giuseppe
