always boot into ROMMON ,can manually boot from flash
Sonnywo
My cisco2921 router always boots into ROMMON. I can manually boot it by using the IOS in flash0.
What's the problem? what can I do?
Thanks in advance!
The following is the output of console:
System Bootstrap, Version 15.0(1r)M16, RELEASE SOFTWARE (fc1)
Copyright (c) 2012 by cisco Systems, Inc.
Total memory size = 512 MB - On-board = 512 MB, DIMM0 = 0 MB
CISCO2921/K9 platform with 524288 Kbytes of main memory
Main memory is configured to 72/-1(On-board/DIMM0) bit mode with ECC enabled
Readonly ROMMON initialized
program load complete, entry point: 0x80803000, size: 0x1b340
IOS Image Load Test
___________________
Signature did not verify
Signature DID NOT VERIFY
boot: cannot load "flash0:"
Compact Flash1: Not present
rommon 2 > dir flash0:
Directory of flash0:
2      97991400  -rw-     c2900-universalk9-mz.SPA.152-4.M2.bin
23926    3064      -rw-     cpconfig-29xx.cfg
24307    0         drw-     ccpexp
24837    2464      -rw-     home.shtml
23927    229065    -rw-     crashinfo_20131015-093011-UTC
rommon 3 > boot flash0:c2900-universalk9-mz.SPA.152-4.M2.bin
IOS Image Load Test
___________________
Digitally Signed Release Software
program load complete, entry point: 0x81000000, size: 0x5d736b0
Self decompressing the image : #################################################
C2921>
8 Replies 8
Leo Laohoo
Post the complete output to the command "sh version".
The boot-variable string could be configured to boot into ROMMON.
Thanks!
C2921>show version
Cisco IOS Software, C2900 Software (C2900-UNIVERSALK9-M), Version 15.2(4)M2, REL
EASE SOFTWARE (fc2)
Copyright (c) 1986-2012 by Cisco Systems, Inc.
Compiled Wed 07-Nov-12 14:08 by prod_rel_team
ROM: System Bootstrap, Version 15.0(1r)M16, RELEASE SOFTWARE (fc1)
C2921 uptime is 5 minutes
System image file is "flash0:c2900-universalk9-mz.SPA.152-4.M2.bin"
Last reload type: Normal Reload
Last reload reason: power-on
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
Cisco CISCO2921/K9 (revision 1.0) with 487424K/36864K bytes of memory.
Processor board ID FGL1711115S
3 Gigabit Ethernet interfaces
1 terminal line
DRAM configuration is 64 bits wide with parity enabled.
255K bytes of non-volatile configuration memory.
250880K bytes of ATA System CompactFlash 0 (Read/Write)
License Info:
License UDI:
Device#   PID                   SN
*0        CISCO2921/K9          FGL1711115S
Technology Package License Information for Module:'c2900'
Technology    Technology-package           Technology-package
              Current       Type           Next reboot
ipbase        ipbasek9      Permanent      ipbasek9
security      None          None           None
uc            None          None           None
data          None          None           None
Can we see the output to the following commands:
sh run | include boot
sh bootvar
Update the firmware of the router as well.  The current one is >7 years old.
It works now. Thank you so much!
The output and what I did:
rommon 4 > confreg
           Configuration Summary
   (Virtual Configuration Register: 0x2102)
enabled are:
load rom after netboot fails
console baud: 9600
boot: image specified by the boot system commands
      or default to: cisco2-CISCO2921/K9
do you wish to change the configuration? y/n  [n]:
C2921(config)#boot system flash0 c2900-universalk9-mz.SPA.152-4.M2.bin
The boot variable string syntax is not correct.
The router will boot the first useable image.
syntax is not correct? but the system didn't  give an error:
C2921(config)#exit
C2921#wr
Because you were not watching carefully.  The syntax boot system flash0 c2900-universalk9-mz.SPA.152-4.M2.bin is not correct.
But it is OK.  The developers have coded a fall-back where the router will boot the first useable IOS.
Thanks for you patience!
