another 2901 VWIC card question
jlmickens
I'm still trying to get the circuit connected to my new VWIC card working correctly.  I get a CD light on the VWIC card, as well as an alarm light, but the circuit shows as down/down.  If I throw a hard loop in front of where I plug into the circuit, my interface shows up/up (looped).  I'm trying to do a ping test to make sure my cable is good, but for some reason I can't ping its ip address.
Route2#sh int se0/2/0:0
Serial0/2/0:0 is up, line protocol is up (looped)
  Hardware is DSX1
  Description: T1 to Frontier - Rochester, NY
  Internet address is 72.241.59.73/30
  MTU 1500 bytes, BW 1536 Kbit/sec, DLY 20000 usec,
  Encapsulation HDLC, loopback not set
  Keepalive set (10 sec)
  Last input 00:00:01, output 00:00:01, output hang never
  Last clearing of "show interface" counters 00:24:09
  Queueing strategy: weighted fair
  Output queue: 0/1000/64/0 (size/max total/threshold/drops)
     Conversations  0/2/256 (active/max active/max total)
     Reserved Conversations 0/0 (allocated/max allocated)
     Available Bandwidth 1152 kilobits/sec
     184 packets input, 28232 bytes, 0 no buffer
     Received 169 broadcasts, 0 runts, 0 giants, 0 throttles
     0 input errors, 0 CRC, 0 frame, 0 overrun, 0 ignored, 0 abort
     184 packets output, 28232 bytes, 0 underruns
     0 unknown protocol drops
     0 carrier transitions
  Timeslot(s) Used:1-24, SCC: 0, Transmitter delay is 0 flags
There are no access lists on the interface at all, so I would expect that pinging its own IP address would return results. The other two circuits are able to ping their own IP addresses.  Any ideas?
Relevant config sections (these are set up the same as the other two cards that are working fine):
card type t1 0 2
no network-clock-participate wic 2
controller T1 0/2/0
cablelength long 0db
channel-group 0 timeslots 1-24
interface Serial0/2/0:0
description New T1 circuit
ip address 72.241.59.73 255.255.255.252
ip nat outside
ip virtual-reassembly
6 Replies 6
could you please post the output of "sh  controller se0/2/0:0....
Please config as below,
r1(conf)#default int  se0/2/0:0
r1(conf)#int se0/2/0:0
r1(conf-if)#ip add 72.241.59.73 255.255.255.252
Now try to  do  extended ping as test,
r1#ping ip
Target IP address: 72.241.59.73
Repeat count [5]: 50
Datagram size [100]: 1500
Timeout in seconds [2]:
Extended commands [n]: yes
Source address or interface:
Type of service [0]:
Set DF bit in IP header? [no]:
Validate reply data? [no]:
Data pattern [0xABCD]: 0x0000
Loose, Strict, Record, Timestamp, Verbose[none]:
Sweep range of sizes [n]:
  • Perform additional extended pings with different data patterns. For example:
    Repeat step 1, but use a Data Pattern of 0x0001
    Repeat step 1, but use a Data Pattern of 0x0101
    Repeat step 1, but use a Data Pattern of 0x1111
    Repeat step 1, but use a Data Pattern of 0x5555
    Repeat step 1, but use a Data Pattern of 0xffff
  • Verify that all the extended pings tests were 100 percent successful.
  • Richard Burts
    I appreciate the advice to take the serial interface back to basic configuration as a way to verify that there is not something in the current config that gets in the way. But my attention goes to the part of the original post where it says that without loopback the interface shows as down/down. In that context the output of show controller might be helpful.
    I can see possibilities that the issue might be a bad card in the router, that it might be a bad cable connecting the router to the circuit, or that it might be a problem in the installation of the circuit. The original post says that there are two other circuits that are working so I would suggest moving some things around to see if you can identify the problem. (that assumes that all three circuits were provisioned the same)  If you take the cable from one of the successful curcuits and connect it to the interface that is not working and the circuit stays up then you have proved that the card in the router is ok. If that is not the problem then return all cables to their original locations. They try exchanging the cable that connects the problem interface with the cable from one of the good interfaces. If the "bad" interface comes up and the "good" interface goes down then you have proved that the cable is the problem. If that is not the issue then return all cables to their original position. Then try exchanging the circuit end of the bad interface with one of the circuit connections that is working. If the "bad" interface circuit now comes up then you have demonstrated that there is a problem with the circuit installation.
    Rick
    Rick
    jlmickens
    That's part of the problem - I get no response from a ping test, extended or otherwise.
    Route2#sh controller se0/2/0:0
    Interface Serial0/2/0:0
    Hardware is HDLC32
    HDLC32 resource allocated to this interface:
    Slot:   0,  WIC Slot: 2, Port: 0
    CRC on: 1,  CRC size: 2, idle flags: 1, frame inverted: 0, clocking: 1
    Channel-group: 0, Channel-group bitfield: FFFFFF00
    HDLC channel: 0, HDLC quad used: 00FFFFFF HDLC channel bitfield: 00000001
    Channel HW state: 0, tx_limited:  1, mci_txcount:    2, txring_limit: 2
    Tx Q len: 0, idb throttled: FALSE, input_throttled:  0, input_qcount: 0
    Sof_Sof_Errs:  0, No_Sof_Errs:    0, hdlc_sync_errs: 0, No Buf Err:   0
    spurious_rx_isr_intr: 2, no_eof_fse_err: 0, buf_len_err:    0
    hdlc_info: 0x290581D8
    HDLC32 Register Address: 0x10840000
    Egress Desc Table Address  (0004): 0E241000
    Ingress Desc Table Address (0008): 0E243000
    Channel Enable             (000C): 00000000
    Ingress Link Up/Down       (0024): 00000001
    Channel Assign Control     (0028): 00000003
    Configuration Command      (002C): 00030028
    Interrupt Enable           (0030): 0000006F
    Ingress Maximum Frame Size (0034): 00004669
    TDM Bus Control            (003C): 0000000A
    Rx BD index:   0,   Rx BD Addr:    0xE243004,  Rx BD Val: 0x88800000
    Tx Head index: 0,   Tx Tail index: 0
    RX Ring:
    desc addr: 0x0E243000, data_ptr: 0x0E384844, descriptor: 0x88800000
    desc addr: 0x0E243008, data_ptr: 0x0E384AA4, descriptor: 0x88800000
    desc addr: 0x0E243010, data_ptr: 0x0E384D04, descriptor: 0x88800000
    desc addr: 0x0E243018, data_ptr: 0x0E384F64, descriptor: 0x88800000
    desc addr: 0x0E243020, data_ptr: 0x0E3851C4, descriptor: 0x88800000
    desc addr: 0x0E243028, data_ptr: 0x0E385424, descriptor: 0x88800000
    desc addr: 0x0E243030, data_ptr: 0x0E385684, descriptor: 0x88800000
    desc addr: 0x0E243038, data_ptr: 0x0E3858E4, descriptor: 0x88800000
    desc addr: 0x0E243040, data_ptr: 0x0E385B44, descriptor: 0x88800000
    desc addr: 0x0E243048, data_ptr: 0x0E385DA4, descriptor: 0x88800000
    desc addr: 0x0E243050, data_ptr: 0x0E386004, descriptor: 0x88800000
    desc addr: 0x0E243058, data_ptr: 0x0E386264, descriptor: 0x88800000
    desc addr: 0x0E243060, data_ptr: 0x0E3864C4, descriptor: 0x88800000
    desc addr: 0x0E243068, data_ptr: 0x0E386724, descriptor: 0x88800000
    desc addr: 0x0E243070, data_ptr: 0x0E386984, descriptor: 0x88800000
    desc addr: 0x0E243078, data_ptr: 0x0E386BE4, descriptor: 0x88800080
    desc addr: 0x0E243080, data_ptr: 0x0E386E44, descriptor: 0x88800080
    desc addr: 0x0E243088, data_ptr: 0x0E3870A4, descriptor: 0x88800080
    desc addr: 0x0E243090, data_ptr: 0x0E387304, descriptor: 0x88800080
    desc addr: 0x0E243098, data_ptr: 0x0E387564, descriptor: 0x88800080
    desc addr: 0x0E2430A0, data_ptr: 0x0E3877C4, descriptor: 0x88800080
    desc addr: 0x0E2430A8, data_ptr: 0x0E387A24, descriptor: 0x88800080
    desc addr: 0x0E2430B0, data_ptr: 0x0E387C84, descriptor: 0x88800080
    desc addr: 0x0E2430B8, data_ptr: 0x0E387EE4, descriptor: 0x88800080
    desc addr: 0x0E2430C0, data_ptr: 0x0E388144, descriptor: 0x88800080
    desc addr: 0x0E2430C8, data_ptr: 0x0E3883A4, descriptor: 0x88800080
    desc addr: 0x0E2430D0, data_ptr: 0x0E388604, descriptor: 0x88800080
    desc addr: 0x0E2430D8, data_ptr: 0x0E388864, descriptor: 0x88800080
    desc addr: 0x0E2430E0, data_ptr: 0x0E388AC4, descriptor: 0x88800080
    desc addr: 0x0E2430E8, data_ptr: 0x0E388D24, descriptor: 0x88800080
    desc addr: 0x0E2430F0, data_ptr: 0x0E388F84, descriptor: 0x88800080
    desc addr: 0x0E2430F8, data_ptr: 0x0E3891E4, descriptor: 0x88800100
    desc addr: 0x0E243100, data_ptr: 0x0E389444, descriptor: 0x88800100
    desc addr: 0x0E243108, data_ptr: 0x0E3896A4, descriptor: 0x88800100
    desc addr: 0x0E243110, data_ptr: 0x0E389904, descriptor: 0x88800100
    desc addr: 0x0E243118, data_ptr: 0x0E389B64, descriptor: 0x88800100
    desc addr: 0x0E243120, data_ptr: 0x0E389DC4, descriptor: 0x88800100
    desc addr: 0x0E243128, data_ptr: 0x0E38A024, descriptor: 0x88800100
    desc addr: 0x0E243130, data_ptr: 0x0E38A284, descriptor: 0x88800100
    desc addr: 0x0E243138, data_ptr: 0x0E38A4E4, descriptor: 0x88800100
    desc addr: 0x0E243140, data_ptr: 0x0E38A744, descriptor: 0x88800100
    desc addr: 0x0E243148, data_ptr: 0x0E38A9A4, descriptor: 0x88800100
    desc addr: 0x0E243150, data_ptr: 0x0E38AC04, descriptor: 0x88800100
    desc addr: 0x0E243158, data_ptr: 0x0E38AE64, descriptor: 0x88800100
    desc addr: 0x0E243160, data_ptr: 0x0E38B0C4, descriptor: 0x88800100
    desc addr: 0x0E243168, data_ptr: 0x0E38B324, descriptor: 0x88800100
    desc addr: 0x0E243170, data_ptr: 0x0E38B584, descriptor: 0x88800100
    desc addr: 0x0E243178, data_ptr: 0x0E38B7E4, descriptor: 0x88800180
    desc addr: 0x0E243180, data_ptr: 0x0E38BA44, descriptor: 0x88800180
    desc addr: 0x0E243188, data_ptr: 0x0E38BCA4, descriptor: 0x88800180
    desc addr: 0x0E243190, data_ptr: 0x0E38BF04, descriptor: 0x88800180
    desc addr: 0x0E243198, data_ptr: 0x0E38C164, descriptor: 0x88800180
    desc addr: 0x0E2431A0, data_ptr: 0x0E38C3C4, descriptor: 0x88800180
    desc addr: 0x0E2431A8, data_ptr: 0x0E38C624, descriptor: 0x88800180
    desc addr: 0x0E2431B0, data_ptr: 0x0E38C884, descriptor: 0x88800180
    desc addr: 0x0E2431B8, data_ptr: 0x0E38CAE4, descriptor: 0x88800180
    desc addr: 0x0E2431C0, data_ptr: 0x0E38CD44, descriptor: 0x88800180
    desc addr: 0x0E2431C8, data_ptr: 0x0E38CFA4, descriptor: 0x88800180
    desc addr: 0x0E2431D0, data_ptr: 0x0E38D204, descriptor: 0x88800180
    desc addr: 0x0E2431D8, data_ptr: 0x0E38D464, descriptor: 0x88800180
    desc addr: 0x0E2431E0, data_ptr: 0x0E38D6C4, descriptor: 0x88800180
    desc addr: 0x0E2431E8, data_ptr: 0x0E38D924, descriptor: 0x88800180
    desc addr: 0x0E2431F0, data_ptr: 0x0E38DB84, descriptor: 0x88800180
    desc addr: 0x0E2431F8, data_ptr: 0x0E38DDE4, descriptor: 0x88800200
    desc addr: 0x0E243200, data_ptr: 0x0E38E044, descriptor: 0x88800200
    desc addr: 0x0E243208, data_ptr: 0x0E38E2A4, descriptor: 0x88800200
    desc addr: 0x0E243210, data_ptr: 0x0E38E504, descriptor: 0x88800200
    desc addr: 0x0E243218, data_ptr: 0x0E38E764, descriptor: 0x88800200
    desc addr: 0x0E243220, data_ptr: 0x0E38E9C4, descriptor: 0x88800200
    desc addr: 0x0E243228, data_ptr: 0x0E38EC24, descriptor: 0x88800200
    desc addr: 0x0E243230, data_ptr: 0x0E38EE84, descriptor: 0x88800200
    desc addr: 0x0E243238, data_ptr: 0x0E38F0E4, descriptor: 0x88800200
    desc addr: 0x0E243240, data_ptr: 0x0E38F344, descriptor: 0x88800200
    desc addr: 0x0E243248, data_ptr: 0x0E38F5A4, descriptor: 0x88800200
    desc addr: 0x0E243250, data_ptr: 0x0E38F804, descriptor: 0x88800200
    desc addr: 0x0E243258, data_ptr: 0x0E38FA64, descriptor: 0x88800200
    desc addr: 0x0E243260, data_ptr: 0x0E38FCC4, descriptor: 0x88800200
    desc addr: 0x0E243268, data_ptr: 0x0E38FF24, descriptor: 0x88800200
    desc addr: 0x0E243270, data_ptr: 0x0E390184, descriptor: 0x88800200
    desc addr: 0x0E243278, data_ptr: 0x0E3903E4, descriptor: 0x88800280
    desc addr: 0x0E243280, data_ptr: 0x0E390644, descriptor: 0x88800280
    desc addr: 0x0E243288, data_ptr: 0x0E3908A4, descriptor: 0x88800280
    desc addr: 0x0E243290, data_ptr: 0x0E390B04, descriptor: 0x88800280
    desc addr: 0x0E243298, data_ptr: 0x0E390D64, descriptor: 0x88800280
    desc addr: 0x0E2432A0, data_ptr: 0x0E390FC4, descriptor: 0x88800280
    desc addr: 0x0E2432A8, data_ptr: 0x0E391224, descriptor: 0x88800280
    desc addr: 0x0E2432B0, data_ptr: 0x0E391484, descriptor: 0x88800280
    desc addr: 0x0E2432B8, data_ptr: 0x0E3916E4, descriptor: 0x88800280
    desc addr: 0x0E2432C0, data_ptr: 0x0E391944, descriptor: 0x88800280
    desc addr: 0x0E2432C8, data_ptr: 0x0E391BA4, descriptor: 0x88800280
    desc addr: 0x0E2432D0, data_ptr: 0x0E391E04, descriptor: 0x88800280
    desc addr: 0x0E2432D8, data_ptr: 0x0E392064, descriptor: 0x88800280
    desc addr: 0x0E2432E0, data_ptr: 0x0E3922C4, descriptor: 0x88800280
    desc addr: 0x0E2432E8, data_ptr: 0x0E392524, descriptor: 0x88800280
    desc addr: 0x0E2432F0, data_ptr: 0x0E392784, descriptor: 0x88800280
    desc addr: 0x0E2432F8, data_ptr: 0x0E3929E4, descriptor: 0x88800300
    desc addr: 0x0E243300, data_ptr: 0x0E392C44, descriptor: 0x88800300
    desc addr: 0x0E243308, data_ptr: 0x0E392EA4, descriptor: 0x88800300
    desc addr: 0x0E243310, data_ptr: 0x0E393104, descriptor: 0x88800300
    desc addr: 0x0E243318, data_ptr: 0x0E393364, descriptor: 0x88800300
    desc addr: 0x0E243320, data_ptr: 0x0E3935C4, descriptor: 0x88800300
    desc addr: 0x0E243328, data_ptr: 0x0E393824, descriptor: 0x88800300
    desc addr: 0x0E243330, data_ptr: 0x0E393A84, descriptor: 0x88800300
    desc addr: 0x0E243338, data_ptr: 0x0E393CE4, descriptor: 0x88800300
    desc addr: 0x0E243340, data_ptr: 0x0E393F44, descriptor: 0x88800300
    desc addr: 0x0E243348, data_ptr: 0x0E3941A4, descriptor: 0x88800300
    desc addr: 0x0E243350, data_ptr: 0x0E394404, descriptor: 0x88800300
    desc addr: 0x0E243358, data_ptr: 0x0E394664, descriptor: 0x88800300
    desc addr: 0x0E243360, data_ptr: 0x0E3948C4, descriptor: 0x88800300
    desc addr: 0x0E243368, data_ptr: 0x0E394B24, descriptor: 0x88800300
    desc addr: 0x0E243370, data_ptr: 0x0E394D84, descriptor: 0x88800300
    desc addr: 0x0E243378, data_ptr: 0x0E394FE4, descriptor: 0x88800380
    desc addr: 0x0E243380, data_ptr: 0x0E395244, descriptor: 0x88800380
    desc addr: 0x0E243388, data_ptr: 0x0E3954A4, descriptor: 0x88800380
    desc addr: 0x0E243390, data_ptr: 0x0E395704, descriptor: 0x88800380
    desc addr: 0x0E243398, data_ptr: 0x0E395964, descriptor: 0x88800380
    desc addr: 0x0E2433A0, data_ptr: 0x0E395BC4, descriptor: 0x88800380
    desc addr: 0x0E2433A8, data_ptr: 0x0E395E24, descriptor: 0x88800380
    desc addr: 0x0E2433B0, data_ptr: 0x0E396084, descriptor: 0x88800380
    desc addr: 0x0E2433B8, data_ptr: 0x0E3962E4, descriptor: 0x88800380
    desc addr: 0x0E2433C0, data_ptr: 0x0E396544, descriptor: 0x88800380
    desc addr: 0x0E2433C8, data_ptr: 0x0E3967A4, descriptor: 0x88800380
    desc addr: 0x0E2433D0, data_ptr: 0x0E396A04, descriptor: 0x88800380
    desc addr: 0x0E2433D8, data_ptr: 0x0E396C64, descriptor: 0x88800380
    desc addr: 0x0E2433E0, data_ptr: 0x0E396EC4, descriptor: 0x88800380
    desc addr: 0x0E2433E8, data_ptr: 0x0E397124, descriptor: 0x88800380
    desc addr: 0x0E2433F0, data_ptr: 0x0E397384, descriptor: 0x88800380
    desc addr: 0x0E2433F8, data_ptr: 0x0E3975E4, descriptor: 0x88800400
    desc addr: 0x0E243400, data_ptr: 0x0E397844, descriptor: 0x88800400
    desc addr: 0x0E243408, data_ptr: 0x0E397AA4, descriptor: 0x88800400
    desc addr: 0x0E243410, data_ptr: 0x0E397D04, descriptor: 0x88800400
    desc addr: 0x0E243418, data_ptr: 0x0E397F64, descriptor: 0x88800400
    desc addr: 0x0E243420, data_ptr: 0x0E3981C4, descriptor: 0x88800400
    desc addr: 0x0E243428, data_ptr: 0x0E398424, descriptor: 0x88800400
    desc addr: 0x0E243430, data_ptr: 0x0E398684, descriptor: 0x88800400
    desc addr: 0x0E243438, data_ptr: 0x0E3988E4, descriptor: 0x88800400
    desc addr: 0x0E243440, data_ptr: 0x0E398B44, descriptor: 0x88800400
    desc addr: 0x0E243448, data_ptr: 0x0E398DA4, descriptor: 0x88800400
    desc addr: 0x0E243450, data_ptr: 0x0E399004, descriptor: 0x88800400
    desc addr: 0x0E243458, data_ptr: 0x0E399264, descriptor: 0x88800400
    desc addr: 0x0E243460, data_ptr: 0x0E3994C4, descriptor: 0x88800400
    desc addr: 0x0E243468, data_ptr: 0x0E399724, descriptor: 0x88800400
    desc addr: 0x0E243470, data_ptr: 0x0E399984, descriptor: 0x88800400
    desc addr: 0x0E243478, data_ptr: 0x0E399BE4, descriptor: 0x88800480
    desc addr: 0x0E243480, data_ptr: 0x0E399E44, descriptor: 0x88800480
    desc addr: 0x0E243488, data_ptr: 0x0E39A0A4, descriptor: 0x88800480
    desc addr: 0x0E243490, data_ptr: 0x0E39A304, descriptor: 0x88800480
    desc addr: 0x0E243498, data_ptr: 0x0E39A564, descriptor: 0x88800480
    desc addr: 0x0E2434A0, data_ptr: 0x0E39A7C4, descriptor: 0x88800480
    desc addr: 0x0E2434A8, data_ptr: 0x0E39AA24, descriptor: 0x88800480
    desc addr: 0x0E2434B0, data_ptr: 0x0E39AC84, descriptor: 0x88800480
    desc addr: 0x0E2434B8, data_ptr: 0x0E39AEE4, descriptor: 0x88800480
    desc addr: 0x0E2434C0, data_ptr: 0x0E39B144, descriptor: 0x88800480
    desc addr: 0x0E2434C8, data_ptr: 0x0E39B3A4, descriptor: 0x88800480
    desc addr: 0x0E2434D0, data_ptr: 0x0E39B604, descriptor: 0x88800480
    desc addr: 0x0E2434D8, data_ptr: 0x0E39B864, descriptor: 0x88800480
    desc addr: 0x0E2434E0, data_ptr: 0x0E39BAC4, descriptor: 0x88800480
    desc addr: 0x0E2434E8, data_ptr: 0x0E39BD24, descriptor: 0x88800480
    desc addr: 0x0E2434F0, data_ptr: 0x0E39BF84, descriptor: 0x88800480
    desc addr: 0x0E2434F8, data_ptr: 0x0E39C1E4, descriptor: 0x88800500
    desc addr: 0x0E243500, data_ptr: 0x0E39C444, descriptor: 0x88800500
    desc addr: 0x0E243508, data_ptr: 0x0E39C6A4, descriptor: 0x88800500
    desc addr: 0x0E243510, data_ptr: 0x0E39C904, descriptor: 0x88800500
    desc addr: 0x0E243518, data_ptr: 0x0E39CB64, descriptor: 0x88800500
    desc addr: 0x0E243520, data_ptr: 0x0E39CDC4, descriptor: 0x88800500
    desc addr: 0x0E243528, data_ptr: 0x0E39D024, descriptor: 0x88800500
    desc addr: 0x0E243530, data_ptr: 0x0E39D284, descriptor: 0x88800500
    desc addr: 0x0E243538, data_ptr: 0x0E39D4E4, descriptor: 0x88800500
    desc addr: 0x0E243540, data_ptr: 0x0E39D744, descriptor: 0x88800500
    desc addr: 0x0E243548, data_ptr: 0x0E39D9A4, descriptor: 0x88800500
    desc addr: 0x0E243550, data_ptr: 0x0E39DC04, descriptor: 0x88800500
    desc addr: 0x0E243558, data_ptr: 0x0E39DE64, descriptor: 0x88800500
    desc addr: 0x0E243560, data_ptr: 0x0E39E0C4, descriptor: 0x88800500
    desc addr: 0x0E243568, data_ptr: 0x0E39E324, descriptor: 0x88800500
    desc addr: 0x0E243570, data_ptr: 0x0E39E584, descriptor: 0x88800500
    desc addr: 0x0E243578, data_ptr: 0x0E39E7E4, descriptor: 0x88800580
    desc addr: 0x0E243580, data_ptr: 0x0E39EA44, descriptor: 0x88800580
    desc addr: 0x0E243588, data_ptr: 0x0E39ECA4, descriptor: 0x88800580
    desc addr: 0x0E243590, data_ptr: 0x0E39EF04, descriptor: 0x88800580
    desc addr: 0x0E243598, data_ptr: 0x0E39F164, descriptor: 0x88800580
    desc addr: 0x0E2435A0, data_ptr: 0x0E39F3C4, descriptor: 0x88800580
    desc addr: 0x0E2435A8, data_ptr: 0x0E39F624, descriptor: 0x88800580
    desc addr: 0x0E2435B0, data_ptr: 0x0E39F884, descriptor: 0x88800580
    desc addr: 0x0E2435B8, data_ptr: 0x0E39FAE4, descriptor: 0x88800580
    desc addr: 0x0E2435C0, data_ptr: 0x0E39FD44, descriptor: 0x88800580
    desc addr: 0x0E2435C8, data_ptr: 0x0E39FFA4, descriptor: 0x88800580
    desc addr: 0x0E2435D0, data_ptr: 0x0E3A0204, descriptor: 0x88800580
    desc addr: 0x0E2435D8, data_ptr: 0x0E3A0464, descriptor: 0x88800580
    desc addr: 0x0E2435E0, data_ptr: 0x0E3A06C4, descriptor: 0x88800580
    desc addr: 0x0E2435E8, data_ptr: 0x0E3A0924, descriptor: 0x88800580
    desc addr: 0x0E2435F0, data_ptr: 0x0E3A0B84, descriptor: 0x88800580
    desc addr: 0x0E2435F8, data_ptr: 0x0E3A0DE4, descriptor: 0x88800600
    desc addr: 0x0E243600, data_ptr: 0x0E3A1044, descriptor: 0x88800600
    desc addr: 0x0E243608, data_ptr: 0x0E3A12A4, descriptor: 0x88800600
    desc addr: 0x0E243610, data_ptr: 0x0E3A1504, descriptor: 0x88800600
    desc addr: 0x0E243618, data_ptr: 0x0E3A1764, descriptor: 0x88800600
    desc addr: 0x0E243620, data_ptr: 0x0E3A19C4, descriptor: 0x88800600
    desc addr: 0x0E243628, data_ptr: 0x0E3A1C24, descriptor: 0x88800600
    desc addr: 0x0E243630, data_ptr: 0x0E3A1E84, descriptor: 0x88800600
    desc addr: 0x0E243638, data_ptr: 0x0E3A20E4, descriptor: 0x88800600
    desc addr: 0x0E243640, data_ptr: 0x0E3A2344, descriptor: 0x88800600
    desc addr: 0x0E243648, data_ptr: 0x0E3A25A4, descriptor: 0x88800600
    desc addr: 0x0E243650, data_ptr: 0x0E3A2804, descriptor: 0x88800600
    desc addr: 0x0E243658, data_ptr: 0x0E3A2A64, descriptor: 0x88800600
    desc addr: 0x0E243660, data_ptr: 0x0E3A2CC4, descriptor: 0x88800600
    desc addr: 0x0E243668, data_ptr: 0x0E3A2F24, descriptor: 0x88800600
    desc addr: 0x0E243670, data_ptr: 0x0E3A3184, descriptor: 0x88800600
    desc addr: 0x0E243678, data_ptr: 0x0E3A33E4, descriptor: 0x88800680
    desc addr: 0x0E243680, data_ptr: 0x0E3A3644, descriptor: 0x88800680
    desc addr: 0x0E243688, data_ptr: 0x0E3A38A4, descriptor: 0x88800680
    desc addr: 0x0E243690, data_ptr: 0x0E3A3B04, descriptor: 0x88800680
    desc addr: 0x0E243698, data_ptr: 0x0E3A3D64, descriptor: 0x88800680
    desc addr: 0x0E2436A0, data_ptr: 0x0E3A3FC4, descriptor: 0x88800680
    desc addr: 0x0E2436A8, data_ptr: 0x0E3A4224, descriptor: 0x88800680
    desc addr: 0x0E2436B0, data_ptr: 0x0E3A4484, descriptor: 0x88800680
    desc addr: 0x0E2436B8, data_ptr: 0x0E3A46E4, descriptor: 0x88800680
    desc addr: 0x0E2436C0, data_ptr: 0x0E3A4944, descriptor: 0x88800680
    desc addr: 0x0E2436C8, data_ptr: 0x0E3A4BA4, descriptor: 0x88800680
    desc addr: 0x0E2436D0, data_ptr: 0x0E3A4E04, descriptor: 0x88800680
    desc addr: 0x0E2436D8, data_ptr: 0x0E3A5064, descriptor: 0x88800680
    desc addr: 0x0E2436E0, data_ptr: 0x0E3A52C4, descriptor: 0x88800680
    desc addr: 0x0E2436E8, data_ptr: 0x0E3A5524, descriptor: 0x88800680
    desc addr: 0x0E2436F0, data_ptr: 0x0E3A5784, descriptor: 0x88800680
    desc addr: 0x0E2436F8, data_ptr: 0x0E3A59E4, descriptor: 0x88800700
    desc addr: 0x0E243700, data_ptr: 0x0E3A5C44, descriptor: 0x88800700
    desc addr: 0x0E243708, data_ptr: 0x0E3A5EA4, descriptor: 0x88800700
    desc addr: 0x0E243710, data_ptr: 0x0E3A6104, descriptor: 0x88800700
    desc addr: 0x0E243718, data_ptr: 0x0E3A6364, descriptor: 0x88800700
    desc addr: 0x0E243720, data_ptr: 0x0E3A65C4, descriptor: 0x88800700
    desc addr: 0x0E243728, data_ptr: 0x0E3A6824, descriptor: 0x88800700
    desc addr: 0x0E243730, data_ptr: 0x0E3A6A84, descriptor: 0x88800700
    desc addr: 0x0E243738, data_ptr: 0x0E3A6CE4, descriptor: 0x88800700
    desc addr: 0x0E243740, data_ptr: 0x0E3A6F44, descriptor: 0x88800700
    desc addr: 0x0E243748, data_ptr: 0x0E3A71A4, descriptor: 0x88800700
    desc addr: 0x0E243750, data_ptr: 0x0E3A7404, descriptor: 0x88800700
    desc addr: 0x0E243758, data_ptr: 0x0E3A7664, descriptor: 0x88800700
    desc addr: 0x0E243760, data_ptr: 0x0E3A78C4, descriptor: 0x88800700
    desc addr: 0x0E243768, data_ptr: 0x0E3A7B24, descriptor: 0x88800700
    desc addr: 0x0E243770, data_ptr: 0x0E3A7D84, descriptor: 0x88800700
    desc addr: 0x0E243778, data_ptr: 0x0E3A7FE4, descriptor: 0x88800780
    desc addr: 0x0E243780, data_ptr: 0x0E3A8244, descriptor: 0x88800780
    desc addr: 0x0E243788, data_ptr: 0x0E3A84A4, descriptor: 0x88800780
    desc addr: 0x0E243790, data_ptr: 0x0E3A8704, descriptor: 0x88800780
    desc addr: 0x0E243798, data_ptr: 0x0E3A8964, descriptor: 0x88800780
    desc addr: 0x0E2437A0, data_ptr: 0x0E3A8BC4, descriptor: 0x88800780
    desc addr: 0x0E2437A8, data_ptr: 0x0E3A8E24, descriptor: 0x88800780
    desc addr: 0x0E2437B0, data_ptr: 0x0E3A9084, descriptor: 0x88800780
    desc addr: 0x0E2437B8, data_ptr: 0x0E3A92E4, descriptor: 0x88800780
    desc addr: 0x0E2437C0, data_ptr: 0x0E3A9544, descriptor: 0x88800780
    desc addr: 0x0E2437C8, data_ptr: 0x0E3A97A4, descriptor: 0x88800780
    desc addr: 0x0E2437D0, data_ptr: 0x0E3A9A04, descriptor: 0x88800780
    desc addr: 0x0E2437D8, data_ptr: 0x0E3A9C64, descriptor: 0x88800780
    desc addr: 0x0E2437E0, data_ptr: 0x0E3A9EC4, descriptor: 0x88800780
    desc addr: 0x0E2437E8, data_ptr: 0x0E3AA124, descriptor: 0x88800780
    desc addr: 0x0E2437F0, data_ptr: 0x0E3AA384, descriptor: 0x88800780
    desc addr: 0x0E2437F8, data_ptr: 0x0E3AA5E4, descriptor: 0x88800800
    desc addr: 0x0E243800, data_ptr: 0x0E3AA844, descriptor: 0x88800800
    desc addr: 0x0E243808, data_ptr: 0x0E3AAAA4, descriptor: 0x88800800
    desc addr: 0x0E243810, data_ptr: 0x0E3AAD04, descriptor: 0x88800800
    desc addr: 0x0E243818, data_ptr: 0x0E3AAF64, descriptor: 0x88800800
    desc addr: 0x0E243820, data_ptr: 0x0E3AB1C4, descriptor: 0x88800800
    desc addr: 0x0E243828, data_ptr: 0x0E3AB424, descriptor: 0x88800800
    desc addr: 0x0E243830, data_ptr: 0x0E3AB684, descriptor: 0x88800800
    desc addr: 0x0E243838, data_ptr: 0x0E3AB8E4, descriptor: 0x88800800
    desc addr: 0x0E243840, data_ptr: 0x0E3ABB44, descriptor: 0x88800800
    desc addr: 0x0E243848, data_ptr: 0x0E3ABDA4, descriptor: 0x88800800
    desc addr: 0x0E243850, data_ptr: 0x0E3AC004, descriptor: 0x88800800
    desc addr: 0x0E243858, data_ptr: 0x0E3AC264, descriptor: 0x88800800
    desc addr: 0x0E243860, data_ptr: 0x0E3AC4C4, descriptor: 0x88800800
    desc addr: 0x0E243868, data_ptr: 0x0E3AC724, descriptor: 0x88800800
    desc addr: 0x0E243870, data_ptr: 0x0E3AC984, descriptor: 0x88800800
    desc addr: 0x0E243878, data_ptr: 0x0E3ACBE4, descriptor: 0x88800880
    desc addr: 0x0E243880, data_ptr: 0x0E3ACE44, descriptor: 0x88800880
    desc addr: 0x0E243888, data_ptr: 0x0E3AD0A4, descriptor: 0x88800880
    desc addr: 0x0E243890, data_ptr: 0x0E3AD304, descriptor: 0x88800880
    desc addr: 0x0E243898, data_ptr: 0x0E3AD564, descriptor: 0x88800880
    desc addr: 0x0E2438A0, data_ptr: 0x0E3AD7C4, descriptor: 0x88800880
    desc addr: 0x0E2438A8, data_ptr: 0x0E3ADA24, descriptor: 0x88800880
    desc addr: 0x0E2438B0, data_ptr: 0x0E3ADC84, descriptor: 0x88800880
    desc addr: 0x0E2438B8, data_ptr: 0x0E3ADEE4, descriptor: 0x88800880
    desc addr: 0x0E2438C0, data_ptr: 0x0E3AE144, descriptor: 0x88800880
    desc addr: 0x0E2438C8, data_ptr: 0x0E3AE3A4, descriptor: 0x88800880
    desc addr: 0x0E2438D0, data_ptr: 0x0E3AE604, descriptor: 0x88800880
    desc addr: 0x0E2438D8, data_ptr: 0x0E3AE864, descriptor: 0x88800880
    desc addr: 0x0E2438E0, data_ptr: 0x0E3AEAC4, descriptor: 0x88800880
    desc addr: 0x0E2438E8, data_ptr: 0x0E3AED24, descriptor: 0x88800880
    desc addr: 0x0E2438F0, data_ptr: 0x0E3AEF84, descriptor: 0x88800880
    desc addr: 0x0E2438F8, data_ptr: 0x0E3AF1E4, descriptor: 0x88800900
    desc addr: 0x0E243900, data_ptr: 0x0E3AF444, descriptor: 0x88800900
    desc addr: 0x0E243908, data_ptr: 0x0E3AF6A4, descriptor: 0x88800900
    desc addr: 0x0E243910, data_ptr: 0x0E3AF904, descriptor: 0x88800900
    desc addr: 0x0E243918, data_ptr: 0x0E3AFB64, descriptor: 0x88800900
    desc addr: 0x0E243920, data_ptr: 0x0E3AFDC4, descriptor: 0x88800900
    desc addr: 0x0E243928, data_ptr: 0x0E3B0024, descriptor: 0x88800900
    desc addr: 0x0E243930, data_ptr: 0x0E3B0284, descriptor: 0x88800900
    desc addr: 0x0E243938, data_ptr: 0x0E3B04E4, descriptor: 0x88800900
    desc addr: 0x0E243940, data_ptr: 0x0E3B0744, descriptor: 0x88800900
    desc addr: 0x0E243948, data_ptr: 0x0E3B09A4, descriptor: 0x88800900
    desc addr: 0x0E243950, data_ptr: 0x0E3B0C04, descriptor: 0x88800900
    desc addr: 0x0E243958, data_ptr: 0x0E3B0E64, descriptor: 0x88800900
    desc addr: 0x0E243960, data_ptr: 0x0E3B10C4, descriptor: 0x88800900
    desc addr: 0x0E243968, data_ptr: 0x0E3B1324, descriptor: 0x88800900
    desc addr: 0x0E243970, data_ptr: 0x0E3B1584, descriptor: 0x88800900
    desc addr: 0x0E243978, data_ptr: 0x0E3B17E4, descriptor: 0x88800980
    desc addr: 0x0E243980, data_ptr: 0x0E3B1A44, descriptor: 0x88800980
    desc addr: 0x0E243988, data_ptr: 0x0E3B1CA4, descriptor: 0x88800980
    desc addr: 0x0E243990, data_ptr: 0x0E3B1F04, descriptor: 0x88800980
    desc addr: 0x0E243998, data_ptr: 0x0E3B2164, descriptor: 0x88800980
    desc addr: 0x0E2439A0, data_ptr: 0x0E3B23C4, descriptor: 0x88800980
    desc addr: 0x0E2439A8, data_ptr: 0x0E3B2624, descriptor: 0x88800980
    desc addr: 0x0E2439B0, data_ptr: 0x0E3B2884, descriptor: 0x88800980
    desc addr: 0x0E2439B8, data_ptr: 0x0E3B2AE4, descriptor: 0x88800980
    desc addr: 0x0E2439C0, data_ptr: 0x0E3B2D44, descriptor: 0x88800980
    desc addr: 0x0E2439C8, data_ptr: 0x0E3B2FA4, descriptor: 0x88800980
    desc addr: 0x0E2439D0, data_ptr: 0x0E3B3204, descriptor: 0x88800980
    desc addr: 0x0E2439D8, data_ptr: 0x0E3B3464, descriptor: 0x88800980
    desc addr: 0x0E2439E0, data_ptr: 0x0E3B36C4, descriptor: 0x88800980
    desc addr: 0x0E2439E8, data_ptr: 0x0E3B3924, descriptor: 0x88800980
    desc addr: 0x0E2439F0, data_ptr: 0x0E3B3B84, descriptor: 0x88800980
    desc addr: 0x0E2439F8, data_ptr: 0x0E3B3DE4, descriptor: 0x88800A00
    desc addr: 0x0E243A00, data_ptr: 0x0E3B4044, descriptor: 0x88800A00
    desc addr: 0x0E243A08, data_ptr: 0x0E3B42A4, descriptor: 0x88800A00
    desc addr: 0x0E243A10, data_ptr: 0x0E3B4504, descriptor: 0x88800A00
    desc addr: 0x0E243A18, data_ptr: 0x0E3B4764, descriptor: 0x88800A00
    desc addr: 0x0E243A20, data_ptr: 0x0E3B49C4, descriptor: 0x88800A00
    desc addr: 0x0E243A28, data_ptr: 0x0E3B4C24, descriptor: 0x88800A00
    desc addr: 0x0E243A30, data_ptr: 0x0E3B4E84, descriptor: 0x88800A00
    desc addr: 0x0E243A38, data_ptr: 0x0E3B50E4, descriptor: 0x88800A00
    desc addr: 0x0E243A40, data_ptr: 0x0E3B5344, descriptor: 0x88800A00
    desc addr: 0x0E243A48, data_ptr: 0x0E3B55A4, descriptor: 0x88800A00
    desc addr: 0x0E243A50, data_ptr: 0x0E3B5804, descriptor: 0x88800A00
    desc addr: 0x0E243A58, data_ptr: 0x0E3B5A64, descriptor: 0x88800A00
    desc addr: 0x0E243A60, data_ptr: 0x0E3B5CC4, descriptor: 0x88800A00
    desc addr: 0x0E243A68, data_ptr: 0x0E3B5F24, descriptor: 0x88800A00
    desc addr: 0x0E243A70, data_ptr: 0x0E3B6184, descriptor: 0x88800A00
    desc addr: 0x0E243A78, data_ptr: 0x0E3B63E4, descriptor: 0x88800A80
    desc addr: 0x0E243A80, data_ptr: 0x0E3B6644, descriptor: 0x88800A80
    desc addr: 0x0E243A88, data_ptr: 0x0E3B68A4, descriptor: 0x88800A80
    desc addr: 0x0E243A90, data_ptr: 0x0E3B6B04, descriptor: 0x88800A80
    desc addr: 0x0E243A98, data_ptr: 0x0E3B6D64, descriptor: 0x88800A80
    desc addr: 0x0E243AA0, data_ptr: 0x0E3B6FC4, descriptor: 0x88800A80
    desc addr: 0x0E243AA8, data_ptr: 0x0E3B7224, descriptor: 0x88800A80
    desc addr: 0x0E243AB0, data_ptr: 0x0E3B7484, descriptor: 0x88800A80
    desc addr: 0x0E243AB8, data_ptr: 0x0E3B76E4, descriptor: 0x88800A80
    desc addr: 0x0E243AC0, data_ptr: 0x0E3B7944, descriptor: 0x88800A80
    desc addr: 0x0E243AC8, data_ptr: 0x0E3B7BA4, descriptor: 0x88800A80
    desc addr: 0x0E243AD0, data_ptr: 0x0E3B7E04, descriptor: 0x88800A80
    desc addr: 0x0E243AD8, data_ptr: 0x0E3B8064, descriptor: 0x88800A80
    desc addr: 0x0E243AE0, data_ptr: 0x0E3B82C4, descriptor: 0x88800A80
    desc addr: 0x0E243AE8, data_ptr: 0x0E3B8524, descriptor: 0x88800A80
    desc addr: 0x0E243AF0, data_ptr: 0x0E3B8784, descriptor: 0x88800A80
    desc addr: 0x0E243AF8, data_ptr: 0x0E3B89E4, descriptor: 0x88800B00
    desc addr: 0x0E243B00, data_ptr: 0x0E3B8C44, descriptor: 0x88800B00
    desc addr: 0x0E243B08, data_ptr: 0x0E3B8EA4, descriptor: 0x88800B00
    desc addr: 0x0E243B10, data_ptr: 0x0E3B9104, descriptor: 0x88800B00
    desc addr: 0x0E243B18, data_ptr: 0x0E3B9364, descriptor: 0x88800B00
    desc addr: 0x0E243B20, data_ptr: 0x0E3B95C4, descriptor: 0x88800B00
    desc addr: 0x0E243B28, data_ptr: 0x0E3B9824, descriptor: 0x88800B00
    desc addr: 0x0E243B30, data_ptr: 0x0E3B9A84, descriptor: 0x88800B00
    desc addr: 0x0E243B38, data_ptr: 0x0E3B9CE4, descriptor: 0x88800B00
    desc addr: 0x0E243B40, data_ptr: 0x0E3B9F44, descriptor: 0x88800B00
    desc addr: 0x0E243B48, data_ptr: 0x0E3BA1A4, descriptor: 0x88800B00
    desc addr: 0x0E243B50, data_ptr: 0x0E3BA404, descriptor: 0x88800B00
    desc addr: 0x0E243B58, data_ptr: 0x0E3BA664, descriptor: 0x88800B00
    desc addr: 0x0E243B60, data_ptr: 0x0E3BA8C4, descriptor: 0x88800B00
    desc addr: 0x0E243B68, data_ptr: 0x0E3BAB24, descriptor: 0x88800B00
    desc addr: 0x0E243B70, data_ptr: 0x0E3BAD84, descriptor: 0x88800B00
    desc addr: 0x0E243B78, data_ptr: 0x0E3BAFE4, descriptor: 0x88800B80
    desc addr: 0x0E243B80, data_ptr: 0x0E3BB244, descriptor: 0x88800B80
    desc addr: 0x0E243B88, data_ptr: 0x0E3BB4A4, descriptor: 0x88800B80
    desc addr: 0x0E243B90, data_ptr: 0x0E3BB704, descriptor: 0x88800B80
    desc addr: 0x0E243B98, data_ptr: 0x0E3BB964, descriptor: 0x88800B80
    desc addr: 0x0E243BA0, data_ptr: 0x0E3BBBC4, descriptor: 0x88800B80
    desc addr: 0x0E243BA8, data_ptr: 0x0E3BBE24, descriptor: 0x88800B80
    desc addr: 0x0E243BB0, data_ptr: 0x0E3BC084, descriptor: 0x88800B80
    desc addr: 0x0E243BB8, data_ptr: 0x0E3BC2E4, descriptor: 0x88800B80
    desc addr: 0x0E243BC0, data_ptr: 0x0E3BC544, descriptor: 0x88800B80
    desc addr: 0x0E243BC8, data_ptr: 0x0E3BC7A4, descriptor: 0x88800B80
    desc addr: 0x0E243BD0, data_ptr: 0x0E3BCA04, descriptor: 0x88800B80
    desc addr: 0x0E243BD8, data_ptr: 0x0E3BCC64, descriptor: 0x88800B80
    desc addr: 0x0E243BE0, data_ptr: 0x0E3BCEC4, descriptor: 0x88800B80
    desc addr: 0x0E243BE8, data_ptr: 0x0E3BD124, descriptor: 0x88800B80
    desc addr: 0x0E243BF0, data_ptr: 0x0E3BD384, descriptor: 0x88800B80
    desc addr: 0x0E243BF8, data_ptr: 0x0E3BD5E4, descriptor: 0x88800000
    TX Ring:
    data_ptr: 0x00000000, descriptor: 0x00000000
    data_ptr: 0x00000000, descriptor: 0x00000080
    data_ptr: 0x00000000, descriptor: 0x00000100
    data_ptr: 0x00000000, descriptor: 0x00000180
    data_ptr: 0x00000000, descriptor: 0x00000200
    data_ptr: 0x00000000, descriptor: 0x00000280
    data_ptr: 0x00000000, descriptor: 0x00000300
    data_ptr: 0x00000000, descriptor: 0x00000380
    data_ptr: 0x00000000, descriptor: 0x00000400
    data_ptr: 0x00000000, descriptor: 0x00000480
    data_ptr: 0x00000000, descriptor: 0x00000500
    data_ptr: 0x00000000, descriptor: 0x00000580
    data_ptr: 0x00000000, descriptor: 0x00000600
    data_ptr: 0x00000000, descriptor: 0x00000680
    data_ptr: 0x00000000, descriptor: 0x00000700
    data_ptr: 0x00000000, descriptor: 0x00000780
    data_ptr: 0x00000000, descriptor: 0x00000800
    data_ptr: 0x00000000, descriptor: 0x00000880
    data_ptr: 0x00000000, descriptor: 0x00000900
    data_ptr: 0x00000000, descriptor: 0x00000980
    data_ptr: 0x00000000, descriptor: 0x00000A00
    data_ptr: 0x00000000, descriptor: 0x00000A80
    data_ptr: 0x00000000, descriptor: 0x00000B00
    data_ptr: 0x00000000, descriptor: 0x00000B80
    hdlc_chan hdlc_quad owner_idb chan chan_bitfield wic_slot port
    0         FFFFFF    298B08A8  0    FFFFFF00      2        0
    0         FFFFFF    0         0    FFFFFF00      2        0
    -1        0         0         0    0             0        0
    -1        0         0         0    0             0        0
    -1        0         0         0    0             0        0
    -1        0         0         0    0             0        0
    -1        0         0         0    0             0        0
    -1        0         0         0    0             0        0
    -1        0         0         0    0             0        0
    -1        0         0         0    0             0        0
    jlmickens
    Wow - this thread really does not want to display correctly for me...
    @Richard - since originally posting this, I have done many things to try and get it to work, including changing the framing settings, line code settings, etc.  I changed cables with a known working one - problem stayed with the circuit.  I swapped cards - problem stayed with the circuit.  I connected the circuit to the card in slot0/0/0, which is configured the same as far as framing, etc (just a different IP) and I could still not see the loop that the telco had put on the circuit.
    The telco is sending someone out, though they think they've proven the problem is not theirs when they were able to see my hard loop at the router end.  I still think it's theirs, as all my tests indicate that it is.
    jlmickens
    This turned out to be an issue with the RJ48X jack extension from the DMARC.  LEC messed with it for 3 hours to get it to work - lol.
    I still find it odd I couldn't ping my own IP address when I had a hard loopback on it.  This whole setup is very odd.  There is probably a cleaner way of doing this.  I will likely post a different discussion topic for it.
    Richard Burts
    Thanks for posting back that the problem is solved. A problem with the circuit extension is certainly consistent with the testing that you performed.
    Rick
    Rick
