05-26-2006 05:59 AM - edited 03-03-2019 12:49 PM
I need to setup a multilink PPP using two T1 lines. I've read as much as I can find on these forums regarging this. The setups that I've seen seem pretty straight forward. What I can't seem to find an answer for is, whether or not I need to use a policy map. Some documentation says I need it some don't say anything about it. Some of the examples I've seen in the forum has it some doesn't. I'm using two 2650XM routers both running IOS 12.2(8)T5
So, to make a short story long. Do I need to use a policy map? If so, any examples of a fundamental map would greatly help.
Thanks in advance!
05-26-2006 06:50 AM
I have setup many multilink interfaces and I have never used a policy-map. I do not see the need for it in a simple multilink configuration
05-26-2006 09:31 AM
It'll be a couple of weeks before I can try it. But I wanted to get as much info before hand. This will definitly be a simple config, so it should work fine.
Thanks!
