05-08-2013 03:19 AM - edited 03-04-2019 07:50 PM
We have obtained a VOIP service from a service provider for external calls in our company (we already have internal VOIP). They have setup the service and now I just need to get our VOIP server to talk to them. They require that our VOIP server's IP address be set to 192.168.244.250 (their gateway is .10).
So I thought of doing the following. Add a seconday IP to my Main Router of 192.168.244.250 and then just NAT everything through to the VOIP server.
Simple. I thought ... Of course I can't get the natting to work. Please check the following and assist !
Switch (can ping 192.168.1.80 and 192.168.244.250) :
interface Vlan1
ip address 192.168.1.1 255.255.0.0
Main Router:
interface Loopback0
no ip address
ip nat outside
interface GigabitEthernet0/0
ip address 192.168.244.250 255.255.255.0 secondary
ip address 192.168.1.80 255.255.255.0
no ip redirects
ip nat inside
ip virtual-reassembly in
ip policy route-map VOIP_NAT
route-map VOIP_NAT permit 10
match ip address 103
set interface Loopback0
access-list 103 permit ip any host 192.168.244.250
ip nat source static 192.168.1.15 192.168.244.250 extendable no-alias
(The VOIP server btw can not be set to 192.168.244.250 as their are too many VOIP devices on the LAN to change. Neither can it be added as a secondary IP because of some or other network failover features it has).
How I try and test this is to open a browser on my PC to http://192.168.244.250 which should then open the web interface on the VOIP server, but it opens the web interface of the Main Router (or it times out, depending on how I screw up the config).
05-10-2013 12:40 AM
Bump ...
05-10-2013 05:47 AM
Hello Oliver,
Please correct me if I am wrong. You are trying to NAT 192.168.1.0/24 NAT to 192.168.244.250 and all traffic from 192.168.1.0/24 destinated to internet (same range of IPs) should be sent to 192.168.244.10. Right?
I would implement this like this ->
Main Router
interface Gi0/0
no shut
interface Gi0/0.10
description VoIP_LAN
enc dot 10
ip add 192.168.1.80 255.255.255.0
ip nat inside
interface Gi0/0.20
description VoIP_SP
enc dot 20
ip add 192.168.244.250 255.255.255.0
ip nat outside
ip route 0.0.0.0 0.0.0.0 Gi0/0.20 192.168.244.10
ip access extend NAT_ACL
permit ip 192.168.1.0 0.0.0.255 any
ip nat inside source list NAT_ACL interface Gi0/0.20 overload
Best Regards
Please rate all helpful posts and close solved questions
05-10-2013 05:52 AM
I am trying to nat all traffic to 192.168.244.250 through to 192.168.1.15.
A port forward solution of selected ports from .244.250 to .1.15 would also solve my problem, but for the life of me I could not get that working also (and I have done it successfully numerous times in the past !)
05-10-2013 07:39 AM
OK, it is basically same config as before, with some highlighted changes:
Main Router
interface Gi0/0
no shut
interface Gi0/0.10
enc dot 10
ip nat inside
interface Gi0/0.20
description VoIP_SP
enc dot 20
ip nat outside
ip nat inside source static 192.168.1.15 192.168.244.250
Last command you can replace with port forward alternative
ip nat inside source static tcp/udp 192.168.1.15 inside_port 192.168.244.250 outside_port
Make sure that your routing is correct!
Best Regards
