3900 router
onyx_oyin
Please my Cisco 3900 router is not taking the no auto summary command?
Any work around
Yop, as Rahul said, some commands are not shown no sh run configuration if they are in default state, but it does not mean that they have no a affect.
Try to configure:
auto-summary and you will see this command in configuration, if you then delete that command no auto-summary, it will disapear from configuration, because you returned it to deafult state.
If you want to see configuration with all default values, run #show running-config all
Best Regards
Please rate all helpful posts and close solved questions
Best Regards Please rate all helpful posts and close solved questions
5 Replies 5
blau grana
Level 7
Level 7
Could you be more specific? Do you configure EIGRP or BGP? Can you provide output of error message?
What you exactly mean by "not taking"?
Best Regards
onyx_oyin
It is Eigrp. When you do a sh run the no auto summary command does not show
From Command Lookup Tool -
auto-summary (EIGRP)
To allow automatic summarization of subnet routes into network-level routes, use the auto-summary command in router configuration mode or address-family topology configuration mode. To disable this function and send subprefix routing information across classful network boundaries, use the no form of this command.
auto-summary
no auto-summary
Syntax Description
This command has no arguments or keywords.
Command Default
The behavior of this command is enabled by default (the software does not send subprefix routing information across classful network boundaries).
Cisco IOS Release 15.0(1)M, 12.2(33)SRE, 12.2(33)XNE, Cisco IOS XE Release 2.5, Cisco IOS Release 12.2(33)SXI4 and Later Releases
The behavior of this command is disabled by default (the software sends subprefix routing information across classful network boundaries).
Thus the command default for 15.0 onwards on Routers is DISABLED BY DEFAULT. Earlier it was enabled by default
So you will not see in show runn, but it is still applied.
You could confirm if it is diabled by looking at the output of show ip protocols and it will show you Automatic Summarization is diabled.
Rahul
Pls rate all useful posts
Try to configure:
Best Regards
Thanks a lot I have seen that automatic summarization : disabled
