any connect vpn tunnel ipsec can reach local resource
micskeigbor
We try to set up vpn connect ipsec tunnel and we can not reach the local resources.
If we check the any connect client it doesnt shows the local subnet in non secured routes.
In paper everything should be fine but doesnt work.
Any idea?
Gabor
5 Replies 5
Muhammad Awais Khan
If i understand your question correct, you cannot access local non secure routes which are not part of your split vpn once you connect to VPN ?
Can you post a snapshot of your route details tab form the client ?
In cisco any connect it says Route details Secured Routes IPv4 0.0.0.0/0
also, what is the VPN server, an IOS router, an ASA ? Post the full running configuration of whatever you use as VPN server...
We are using ASA, I cant post the config now.
    It means you're doing full tunnelling. If you want to preserve full-tunnelling, follow this guide to help you get access to Local LAN Resources:
https://www.cisco.com/c/en/us/support/docs/security/asa-5500-x-series-next-generation-firewalls/70847-local-lan-pix-asa.html
Cristian Matei.
