any one can tell me where i can find these visio stencils?
wuxunda163
these icon i find from topology of cisco sba document .but i can'g find these on cisco web site.
any one .can tell me where i can find these icom.visio stencils or ppt icon.
14 Replies 14
hobbe
Level 7
Level 7
i am not shure that the ones you specifically asked for are there but they should be.
http://www.cisco.com/en/US/products/hw/prod_cat_visios.html
http://www.cisco.com/web/about/ac50/ac47/2.html
Good luck
If you have ms-visio installed in your pc, then you can find these type of stencils when you open a new visio application.
Also you can find something from the related sites....
http://www.visiocafe.com/
Please rate if this helped you...
Naidu.
also i install MS-visio 2010,and create a new file for network,but don't find the visio stencial in the sba document.
who can tell me where i can find these new icon.
already check this link before,but i dons't find these icon . thank you!
thank you,naidu.i alredy check the link you list but also don't find the icon like sba document.
i appreciate for you help.
i can't find the stencils like sba topo.But thanks for your help!
john963
There are already many Visio stencils provided by Microsoft which you can download. I exactly don’t know whether above mentioned Visio stencil is there or not, however, you can create new stencils in following way by using Visio 2010
1. On the File menu, point to Shapes, and then click New Stencil.
2. To save the stencil, right-click the stencil title bar, and then click Save.
3. Type a name for your stencil, and then click Save.
fieldr
The short answer appears to be you still can't...!
Given the SBA documents are created by Cisco, only Cisco will be able to provide a Visio Stencil for them; as they have not released them the only ones available specifically from Cisco can be found at...
and
Both of which have been identified by earlier posts.
o.wong
Hi Xunda,
I have a copy of these icons in PPT.
Do you have an email address I can send to?
Kind Regards,
Oliver
Cisco network topology icons are located here:
My company develops Cisco's equipment icons (since 2010) that are here:
The topology icons were created by a Cisco internal person.
Brett
OK,thanks for you help!
2011-07-26
xunda.wu
发件人: brenewma
发送时间: 2011-07-26 03:26:11
收件人: xunda wu
抄送:
主题: - Re: any one can tell me where i canfind these visio stencils?
Re: any one can tell me where i can find these visio stencils?
created by Brett Newman in WAN, Routing and Switching - View the full discussion
Brett
Reply to this message by going to Cisco Support Community
Start a new discussion in WAN, Routing and Switching at Cisco Support Community
Bekele Getachew
use this link:
http://www.cisco.com/c/en/us/solutions/enterprise/design-zone-smart-business-architecture/cvd.html
login may be required.
