high CPU usage in cisco 7613 with rsp720-3cxl
me_noori
Hi everybody,
our cisco 7613 has about  4.5 Gbps  Tx/Rx IP traffic in total, and we run ospf with other cisco cloud for routing I list in the following some our router show.what is your idea about our high cpu usage .Is it in normal range with the listed cards and modules.How can I tune the rsp720 and other SIP-200,400,600 for better performances
why our interrupt rate is high ,and one thing more the total sum of 5sec in separate rows not equal to cpu utilization for five second 50%
show proc cpu sor
CPU utilization for five seconds: 50%/46%; one minute: 54%; five minutes: 59%
 PID Runtime(ms)     Invoked      uSecs   5Sec   1Min   5Min TTY Process
   8   196795220    12640741      15568  1.51%  0.38%  0.26%   0 Check heaps
 224  1048610528  4169501364          0  1.19%  1.45%  1.44%   0 IP Input
  13   374006320  3155162661          0  0.23%  0.26%  0.24%   0 ARP Input
 217   119862004   985030884        121  0.15%  0.32%  0.25%   0 ADJ resolve pro
c
 185      537716  1825736183          0  0.07%  0.03%  0.02%   0 ACE Tunnel Task
 260     1550992  2983272818          0  0.07%  0.13%  0.15%   0 Ethernet Msec T
i
 305    38186336    58050485        657  0.07%  0.02%  0.00%   0 XDR mcast
  34       67208    11707798          5  0.07%  0.00%  0.00%   0 IPC Loadometer
  27      232776    57160812          4  0.07%  0.01%  0.00%   0 IPC Periodic Ti
m
 325    17539200    92894502        188  0.07%  0.15%  0.15%   0 CEF: IPv4 proce
s
 195     7406636    43782487        169  0.07%  0.00%  0.00%   0 esw_vlan_stat_p
r
show ip route summ
IP routing table name is default (0x0)
IP routing table maximum-paths is 32
Route Source    Networks    Subnets     Replicates  Overhead    Memory (bytes)
static          1           120         0           7620        20812
connected       0           313         0           18860       53836
ospf 98         17          4892        0           589020      863984
  Intra-area: 89 Inter-area: 383 External-1: 0 External-2: 0
  NSSA External-1: 0 NSSA External-2: 4437
bgp 12880       0           1           0           60          172
  External: 1 Internal: 0 Local: 0
ospf 410        0           269         0           16220       47344
  Intra-area: 1 Inter-area: 0 External-1: 0 External-2: 268
  NSSA External-1: 0 NSSA External-2: 0
internal        137                                             260544
Total           155         5595        0           631780      1246692
sh module
Mod Ports Card Type                              Model              Serial No.
  1    0  4-subslot SPA Interface Processor-200  7600-SIP-200
  2    0  4-subslot SPA Interface Processor-400  7600-SIP-400
  3   24  CEF720 24 port 1000mb SFP              WS-X6724-SFP
  6    1  1-subslot SPA Interface Processor-600  7600-SIP-600
  7    2  Route Switch Processor 720 (Active)    RSP720-3CXL-GE
  8    2  Route Switch Processor 720 (Cold)      RSP720-3CXL-GE
show ver
System image file is "bootdisk:c7600rsp72043-adventerprisek9-mz.122-33.SRE2.bin"
1 SIP-200 controller .
1 SIP-400 controller (1 Channelized OC3/STM-1).
1 SIP-600 controller (1 TenGigabitEthernet).
2 Virtual Ethernet interfaces
28 Gigabit Ethernet interfaces
1 Ten Gigabit Ethernet interface
1 Channelized STM-1 port
show int vlan 1
  Keepalive not supported
  Last input 00:00:00, output 00:00:00, output hang never
  Last clearing of "show interface" counters 2d23h
  Input queue: 0/75/2886/1830 (size/max/drops/flushes); Total output drops: 0
  Queueing strategy: fifo
  Output queue: 0/40 (size/max)
  5 minute input rate 2380531000 bits/sec, 287383 packets/sec
  5 minute output rate 422133000 bits/sec, 254113 packets/sec
  L2 Switched: ucast: 1200869468 pkt, 101172643240 bytes - mcast: 253599 pkt, 78
873415 bytes
  L3 in Switched: ucast: 60947040633 pkt, 68919665115039 bytes - mcast: 0 pkt, 0
 bytes mcast
  L3 out Switched: ucast: 52594517004 pkt, 9869168832783 bytes mcast: 0 pkt, 0 b
ytes
     62147839148 packets input, 69016175499764 bytes, 0 no buffer
     Received 257634 broadcasts (0 IP multicasts)
     0 runts, 0 giants, 15 throttles
     53647248858 packets output, 10292998021217 bytes, 0 underruns
     0 output errors, 0 interface resets
     0 unknown protocol drops
5 Replies 5
Hello.
Your CPU is busy with interrupts.
Please provide:
 - show int summ;
 - show ibc (collect it 2-4 times with interval of 1 minute);
 - show ip traffic (collect it 3-4 times with interval of 1 minute).
Try to capture traffic that was punted to the RP (debug netdr).
Thank you for your hints and replying
These are our show ibc in 1 min interval
Interface information:
        Interface IBC0/0
        5 minute rx rate 20045000 bits/sec, 30183 packets/sec
        5 minute tx rate 47394000 bits/sec, 60212 packets/sec
        19879272237 packets input, 4006174536193 bytes
        19835355282 broadcasts received
        19808585787 packets output, 3981305571968 bytes
        90548 broadcasts sent
        0 Bridge Packet loopback drops
        19756362091 Packets CEF Switched, 1320184 Packets Fast Switched
        0 Packets SLB Switched, 0 Packets CWAN Switched
        Label switched pkts dropped: 0    Pkts dropped during dma: 339549
        Invalid pkts dropped: 0    Pkts dropped(not cwan consumed): 0
        IPSEC pkts dropped: 635184
        Xconnect pkts processed: 0, dropped: 0
        Xconnect pkt reflection drops: 0
        Total paks copied for process level 0
        Total short paks sent in route cache 2605317676
        Total throttle drops 265338    Input queue drops 5831090
        total spd packets classified (120217214 low, 174503 medium, 3073 high)
        total spd packets dropped (339549 low, 0 medium, 0 high)
        spd prio pkts allowed in due to selective throttling (0 med, 0 high)
        IBC resets   = 1; last at 23:52:49.004 Sat Jan 19 2013
Driver Level Counters: (Cumulative, Zeroed only at Reset)
          Frames          Bytes
  Rx(0)   26537712        3421085217
  Rx(1)   3449063135      2838813650
  Tx(0)   3390340306      2016620276
 Input Drop Frame Count
     Rx0 = 0                Rx1 = 2488435
 Per Queue Receive Errors:
     FRME   OFLW   BUFE   NOENP  DISCRD DISABLE BADCOUNT
 Rx0 0      0      0      0      0        0    0
 Rx1 0      0      0      3633   0        0    0
  Tx Errors/State:
   One Collision Error   = 0            More Collisions       = 0
   No Encap Error        = 0            Deferred Error        = 0
   Loss Carrier Error    = 0            Late Collision Error  = 0
   Excessive Collisions  = 0            Buffer Error          = 0
   Tx Freeze Count       = 0            Tx Intrpt Serv timeout= 1
   Tx Flow State         = FLOW_ON
   Tx Flow Off Count     = 0            Tx Flow On Count      = 0
  Counters collected at Idb:
   Is input throttled    = 0            Throttle Count        = 0
   Rx Resource Errors    = 0            Input Drops           = 2488435
   Input Errors           = 194243
   Output Drops          = 0            Giants/Runts          = 0/0
   Dma Mem Error         = 0            Input Overrun         = 0
Hash match table for multicast (in use 0, maximum 64 entries):
show ibc
        Interface IBC0/0
        5 minute rx rate 20194000 bits/sec, 30412 packets/sec
        5 minute tx rate 47753000 bits/sec, 60663 packets/sec
        19891125514 packets input, 4007158118761 bytes
        19847185365 broadcasts received
        19820407164 packets output, 3982279276274 bytes
        90576 broadcasts sent
        19768178233 Packets CEF Switched, 1321008 Packets Fast Switched
        IPSEC pkts dropped: 635574
        Total short paks sent in route cache 2606549061
        total spd packets classified (120252754 low, 174531 medium, 3074 high)
          Frames          Bytes
  Rx(0)   26550723        3422835145
  Rx(1)   3461063605      176652699
  Tx(0)   3402319442      3368513724
     Rx0 = 0                Rx1 = 2490155
 Rx0 0      0      0      0      0        0    0
  Tx Errors/State:
   Rx Resource Errors    = 0            Input Drops           = 2490155
   Input Errors           = 194358
and sorry what is your idea about total sum of 5sec in separate rows not equal to cpu utilization for five second 50%
Hello.
The output of CPU utilization shows "CPU utilization for five seconds: 50%/46%"
It means that 50% is an overall utilization, of which 46% is by interrupts.
So, summarizing CPU consumption per process, you will be able to get about 4% only (50-46 = 4).
So, you have a lot of interrupts, it probably means you have a lot of CPU punted traffic, that is why I asked for "sh ibc" and other commands.
Could you please provide:
 - show int summ;
 - show ip traffic (collect it 3-4 times with interval of 1 minute);
 - show int switching (collect it 3-4 times with interval of 1 minute)
And run them during a single session; please save the outputs to txt file and attach to the discussion.
From your recent "sh ibc" I see that a lot of traffic (broadcasts?) is going to your RP and this is a problem. You need to investigate what is the traffic is why is it punted to RP. There might be some loop in your network.
To capture traffic you may use debug netdr commands.
But I would suggest you to open the case in Cisco TAC, as for investigation your need to provide "show tech" and other "private" network information that might not be shared here.
Thanks a lot vasilli
please find the show commands in attached file, please help you know TAC is very slow
and please give us some help about netdr ,we have about 4.5 Gig IP traffic if we use that for capturing how change our cpu utilization is it enough for netdr
Thanks again
Hello.
Thanks for output.
TAC is responsive and could help you troubleshooting the case online.
But,
I had no chance to find the traffic pattern from the output.
netdr is completely safe for your box. Please try to capture traffic with netdr - I think this should clarify the traffic pattern.
Could you also provide " show interface" and "sh span-tree" output?
