Anyone know how to save DHCP bindings to FLASH/NVRAM rather than tftp?
jkrawczyk
I have four distribution facilities, which are not large. I have Cisco routers in these sites configured with DHCP servicing the staff at each location.
The problem I have is when these routers go down, all DHCP bindings are lost.
I know I can configure the tftp option to save the bindings to a remote tftp node, but I'm hearing there is a way to save these bindings to flash.
Comments? Solutions?
Best Regards
Jeff
Giuseppe Larosa
Hello Jeff,
there is an option to load a txt file with origin command the device still makes a TFTP request but it may be able to open it to itself.
see
http://www.cisco.com/en/US/docs/ios/ipaddr/configuration/guide/iad_dhcp_svr_cfg_ps6350_TSD_Products_Configuration_Guide_Chapter.html#wp1094752
you also need to enable tftp to serve the file that is on flash.
Example:
ip tftp-server flash:staticbindings.txt
but these are like manual bindings so it may be different from what you look for.
my understanding is that dynamic bindings can be saved to a database agent that actually is just a TFTP server.
Hope to help
Giuseppe
