Better Qos option
Shibu1978
Dear All
We have now connected one of our office branch with a bundle of two E1 configured in multilink mode. management want us to implement QOS for the various traffic and reserve bandwidth for the below
1 Mbps for Avaya IP phone--voice traffic
2 Mbps for Business Applications ( Specific IP to IP communication from HO-branchoffice)
1 Mbps for File transfers, emails etc.
What is the best way to acheive the same so that i can meet all the above requirement smoothly.
Thanks in advance
Shibu
5 Replies 5
Joseph W. Doherty
CBWFQ like:
policy-map sampleQoS
class VoIP
priority 1000
class BusApps
bandwidth percent 40
class class-default
bandwidth percent 20
apply to multi interface.
If you're wondering about 40 and 20 percent, this should preserve the 2:1 bandwidth ratio of those classes without the need to modify reserve bandwith. Class default will do the "etc." traffic. It's configured to not use FQ to preserve the bandwidth ratios (for CBWFQ prior to 12.4.20T). You'll also need to define class-maps for the defined classes to match the correct traffic.
Hi Joe,
Is FQ always a default QoS policy for class-default?
What will happen to etc traffic if class class-default is not included in policy-map sampleQoS?
Thanks.
Hugh
"Is FQ always a default QoS policy for class-default? "
Not 100% positive. I believe it's the default for most CBWFQ although I think the very latest HQF in 12.4T might have FIFO now as the default. For either, it would be whatever is explictly configured.
"What will happen to etc traffic if class class-default is not included in policy-map sampleQoS? "
Again, except(?) for HQF CBWFQ, there's an implicit class-default if it's not explictly defined.
Thanks for your response.
Meanwhile we have the following IOS in place.
Cisco IOS Software, 3800 Software (C3825-SPSERVICESK9-M), Version 12.3(11)T8, RELEASE SOFTWARE (fc3)
Copyright (c) 1986-2005 by Cisco Systems, Inc.
Compiled Thu 06-Oct-05 06:13 by kehsiao
How about QOS with DSCP marking ? can i have some sample command as listed above in u r post.
Shibu
You do realize that DSCP markings only make sense if they are to be used later on? However, believe with your 12.3T release (which if you have maintainence you might want to upgrade to 12.4), you can use the "set dscp" (might be "set ip dscp" under each policy-map class statement. Normally you would set VoIP to DSCP EF, routine traffic to DSCP BE and perhaps your critical business apps to DSCP AF21.
e.g.
class VoIP
set dscp EF
priority 1000
class BusApps
set dscp AF21
class class-default
set dscp BE (or 0)
