apply config-file
Johnson_Mo
Hi team,
after copying a config file from tftp to cisco router, in order for the config file to be applied, I reload the device. is there a command to quickly force the config file to take place?
I did the followings and still the config file wont apply. this is a test lab on GNS3
Router# Copy tftp:config.txt flash:
Once the copy is done
Router# copy flash:config.txt running-config
Router# Wr mem
thanks
pieterh
that should do the job!
NB! the copy to running-config is ADDING lines to the config, so it will not replace the current config
copy to running-config will not remove lines unless explicitly commanded in the config.txt ,
but it will replace a line like "hostname...." and it will remove lines if explicit commanded like "no access-list ...."
if you want to replace the whole config you can
     Copy tftp:config.txt startup-config
     reload  ! (dont save the config when asked)
thanks for the wonderful response!
Joseph W. Doherty
See if your IOS supports the "configure replace" command.
