Applying an access control list for FTPS session
ezel14
Hello all, I am having trouble understanding ACLs and the logic of inbound and outbound traffic. I am trying to allow network 192.168.1.0/24 to the FTPS server 192.168.3.0/24 only if an FTPS session originates from the 192.168.1.0/24 LAN. Network 192.168.2.0/24 shouldn't have access to the server. Is this method correct and is there a more efficient way of doing this?
R1
ip access-list extended SEVER-ACCESS
permit tcp 192.168.1.0 0.0.0.255 host 192.168.3.2 eq 990 (control port)
permit tcp 192.168.1.0 0.0.0.255 host 192.168.3.2 eq 989 (data port)
permit tcp 192.168.1.0 0.0.0.255 host 192.168.3.2 eq 20(control port)
permit tcp 192.168.1.0 0.0.0.255 host 192.168.3.2 eq 21 (data port)
permit ip any any
exit
interface e0/0
ip access-group SEVER-ACCESS in
R2
deny tcp 192.168.2.0 0.0.0.255 host 192.168.3.2
permit ip any any
exit
interface e0/1
luis_cordova
Hi @ezel14
Try this
R4
deny tcp 192.168.2.0 0.0.0.255 host 192.168.3.2 eq 990 (control port)
deny tcp 192.168.2.0 0.0.0.255 host 192.168.3.2 eq 989 (data port)
deny tcp 192.168.2.0 0.0.0.255 host 192.168.3.2 eq 20(control port)
deny tcp 192.168.2.0 0.0.0.255 host 192.168.3.2 eq 21 (data port)
permit ip any any
exit
interface e0/1
ip access-group SEVER-ACCESS out
Hello
For standard acl then these only filter of the source address as such these should be place as close to the destination address as possible, on the other hand using an extended acl which can filter on source and destination addressing these can be placed as close to the source as possible, thus it will negate unwarranted router processes and network bandwidth.
In relation your topology I would suggest you apply that extended acl on R2  on e0/0 interface inbound.
Example:
R2
permit ip any any
interface e0/1
no ip access-group SEVER-ACCESS in
interface e0/0
Kind Regards
Paul
Hello Paul, why would it be placed on R2 interface e0/0 inbound?
Hello
As i have stated you would want to negate that traffic before it leaves rtr2 so not to traverse the network then only be to dropped by the destination rtr/host, applying the filter ingress r2 e0/0 would negate this traffic even reaching its e1/0 interface.
Kind Regards
Paul
