applying outbound ACL on ATM interface
s-durando
I have a Cisco 1841 with the following configuration:
interface ATM0/0/0
description Collegamento ADSL BIT PLUS 1,2M/256
bandwidth 256
no ip address
load-interval 30
no atm ilmi-keepalive
dsl operating-mode auto
interface ATM0/0/0.1 point-to-point
description Mpls ; td-locale ; tgu-locale ; Shasta/ERX1440 ;
mtu 1500
bandwidth 20
ip address 85.42.0.248 255.255.255.0
ip access-group ATM-FILTER out
no snmp trap link-status
pvc 8/35
ubr 240
encapsulation aal5snap
ip access-list extended ATM-FILTER
deny ip any any
The imbound ACL doesn't work. I'm still able to ping a remote IP even if I'm exiting through the WAN interface with the deny any ACL applied on it.
In logs below I'm pinging 10.254.4.6 reachable through WAN interface ATM0/0/0.1.
sh ip route
Codes: C - connected, S - static, R - RIP, M - mobile, B - BGP
D - EIGRP, EX - EIGRP external, O - OSPF, IA - OSPF inter area
N1 - OSPF NSSA external type 1, N2 - OSPF NSSA external type 2
E1 - OSPF external type 1, E2 - OSPF external type 2
i - IS-IS, su - IS-IS summary, L1 - IS-IS level-1, L2 - IS-IS level-2
ia - IS-IS inter area, * - candidate default, U - per-user static route
o - ODR, P - periodic downloaded static route
Gateway of last resort is 0.0.0.0 to network 0.0.0.0
85.0.0.0/24 is subnetted, 1 subnets
C 85.42.0.0 is directly connected, ATM0/0/0.1
10.0.0.0/32 is subnetted, 1 subnets
C 10.39.255.252 is directly connected, Loopback0
S* 0.0.0.0/0 is directly connected, ATM0/0/0.1
ping
Protocol [ip]:
Target IP address: 10.254.4.6
Repeat count [5]: 100
Datagram size [100]:
Timeout in seconds [2]:
Extended commands [n]: y
Source address or interface: loopback 0
Type of service [0]:
Set DF bit in IP header? [no]:
Validate reply data? [no]:
Data pattern [0xABCD]:
Loose, Strict, Record, Timestamp, Verbose[none]:
Sweep range of sizes [n]:
Sending 100, 100-byte ICMP Echos to 10.254.4.6, timeout is 2 seconds:
Packet sent with a source address of 10.39.255.252
Moreover ACL counters don't increase:
01MPIAT1TO10124#sh access-list
Extended IP access list ATM-FILTER
10 deny ip any any
01MPIAT1TO10124#
The same problem persists with different IOS version (12.3(14)T7 and 12.4(7)a).
The same ACL applied in inbound works fine. If I apply it I am disconneted from router because I opened a telnet session from remote site.
Could someone help me?
Stefano
Richard Burts
Stefano
You are encountering a basic behavior of IOS: an outbound access list will NOT filter any traffic that is generated BY the router. The outbound access list will filter any traffic that transits the router but not any traffic generated by the router itself.
As you observe an inbound access list will filter all traffic. But an outbound access list will only filter traffic that passes through the router. This is not particularly well documented, but it has always been true in IOS.
Rick
Rick
