Applying QoS within IPSec and GRE tunnels..
jitendraanbu
Tunnel Diagram
Hi all, I have an uncommon situation and would like Cisco’s take on it.As per the above diagram
We have a requirement where we need to classify and mark traffic on the egress (on the CE routers).
The transmission media for this traffic is PPPoE. This PPPoE transmission is via RF and get’s terminated on the ISP PE routers (as per attached figure).
Once we have L3 reachability between CE sites we build GRE tunnels from the hub site (C) to the two spokes (A & B). Over the GRE we run IPSec . Inside IPSec we enable BGP.
The question:
Our egress classification and marking is meant to be acknowledged and prioritised by the ISP, as you can see this traffic is within two tunnels - can this be done? Assuming both us & the ISP are using Cisco devices running code 12.4 or higher.
Many thnaks,
Jit
Vivek Ganapathi
Level 4
Level 4
Hello Jit,
Firstly, I'm not from Cisco Neither the information i have provided below is a view of Cisco.
IMHO, this is not possible. The reason is, your packet is already encrypted & gets inside the tunnel. Your ISP is just a transit path for you thats all. Not sure as to why you would like your ISP to respect your marking when you have a tunnel going on between sites? You need QoS between your sites, so you can keep your ISP apart from it.
Vivek.
Hello there, thanks for your response. This is exactly how I feel about this as well. It is not doable, as the packets are encrypted & it's transparent to the ISP.
Rgds,
Jit
Hello Jit,
Right. End-to-End QoS would be between your sites within the GRE tunnel. So, ISP wouldn't know as the QoS marking would be encapsulated as well within the GRE header.
So frankly speaking, you must not bother about the ISP's involvement to have your markings acknowledged. Remember, you are running GRE, so you would have the End-to-End QoS between your endpoints only.
Vivek
*Please rate helpful posts
Agai, I agree with you Vivek.
Disappointing no one from Cisco has commented on this.
Rgds,
Jit
