Forward tcp port to server on LAN - Cisco 5510
dgcscisco665
Due to departure of our IT guru I am left to manage our Cisco appliances so please excuse my poor basic knowledge, hopefully this site will help that improve!
I need to forward traffic from an Amazon server to an internal server with a SQL database on it so need to forward TCP 1433 to an internal IP (192.168.252.43) I have created an access rule to allow the amazon IPP through on 1433 but I am unsure how to point the traffic to the SQL server on the LAN.
I expect I will need to create a NAT rule to do this but cannot see how to achieve it.
I have another problem concerning a site to site VPN which establishes OK but does not pass traffic, I will post that question separately.
Any assistance would be gratefully received.
Dave
pompeychimes
Level 4
Level 4
What version of code are you running on the 5510? Issue the "sh ver" command to determine.
James
Hi James, thanks for your reply, the result of the command: "sh ver" is below - hope you can assist
Cisco Adaptive Security Appliance Software Version 8.2(1)
Device Manager Version 6.2(3)
Compiled on Tue 05-May-09 22:45 by builders
System image file is "disk0:/asa821-k8.bin"
Config file at boot was "startup-config"
Fusion-FW02 up 10 days 18 hours
Hardware:   ASA5510, 1024 MB RAM, CPU Pentium 4 Celeron 1600 MHz
Internal ATA Compact Flash, 256MB
BIOS Flash Firmware Hub @ 0xffe00000, 1024KB
Encryption hardware device : Cisco ASA-55x0 on-board accelerator (revision 0x0)
                             Boot microcode   :  CN1000-MC-BOOT-2.00
                             SSL/IKE microcode:  CNLite-MC-SSLm-PLUS-2.03
                             IPSec microcode  :  CNlite-MC-IPSECm-MAIN-2.04
0: Ext: Ethernet0/0         : address is d0d0.fd1d.5b64, irq 9
1: Ext: Ethernet0/1         : address is d0d0.fd1d.5b65, irq 9
2: Ext: Ethernet0/2         : address is d0d0.fd1d.5b66, irq 9
3: Ext: Ethernet0/3         : address is d0d0.fd1d.5b67, irq 9
4: Ext: Management0/0       : address is d0d0.fd1d.5b68, irq 11
5: Int: Not used            : irq 11
6: Int: Not used            : irq 5
Licensed features for this platform:
Maximum Physical Interfaces  : Unlimited
Maximum VLANs                : 100
Inside Hosts                 : Unlimited
Failover                     : Active/Active
VPN-DES                      : Enabled
VPN-3DES-AES                 : Enabled
Security Contexts            : 2
GTP/GPRS                     : Disabled
SSL VPN Peers                : 2
Total VPN Peers              : 250
Shared License               : Disabled
AnyConnect for Mobile        : Disabled
AnyConnect for Linksys phone : Disabled
AnyConnect Essentials        : Disabled
Advanced Endpoint Assessment : Disabled
UC Phone Proxy Sessions      : 2
Total UC Proxy Sessions      : 2
Botnet Traffic Filter        : Disabled
This platform has an ASA 5510 Security Plus license.
