Applying "service-policy output" on a Dialer Interface (887VA)
Ian Stephens
We are trying to apply QoS on a Dialer interface.  Every time we issue the command service-policy output upstream-policy - nothing happens and the config does not get applied.  No error messages appear.
QoS config:
class-map match-any web-class
 match protocol ssh
 match protocol secure-http
 match protocol http
 match protocol dns
policy-map upstream-policy
 class web-class
  bandwidth percent 50
 class class-default
  fair-queue
Dialer config:
interface Dialer0
 description $FW_OUTSIDE$
 ip address xxxxxxxx
 no ip redirects
 no ip unreachables
 no ip proxy-arp
 ip mtu 1492
 ip nbar protocol-discovery
 ip nat outside
 no ip virtual-reassembly in
 encapsulation ppp
 dialer pool 1
 dialer-group 1
 ppp authentication chap pap callin
 ppp chap hostname xxxxx
 ppp chap password xxxxxx
 ppp pap sent-username xxxxx
 ppp ipcp route default
 no cdp enable
This is all new to me so any help, support, tips and suggestions are always greatly appreciated.
Thank you for your help in advance.
Hello.
Please try IOS 15.3(3)M4, as earlier versions had a couple of bugs in QoS over Dialer interface.
PS: one more workaround - try to apply QoS on underlying physical interface.
15 Replies 15
Please provide "show ver" from the device.
Hi Vasilii,
Here is the output of show ver:
Cisco IOS Software, C880 Software (C880DATA-UNIVERSALK9-M), Version 15.4(1)T1, RELEASE SOFTWARE (fc2)
Copyright (c) 1986-2014 by Cisco Systems, Inc.
Compiled Wed 12-Feb-14 06:59 by prod_rel_team
ROM: System Bootstrap, Version 12.4(22r)YB5, RELEASE SOFTWARE (fc1)
xxxxxx.xxxxx.xxxxxx.com uptime is 1 week, 16 hours, 10 minutes
System returned to ROM by reload at 00:04:11 UTC Thu Nov 6 2014
System image file is "flash:c880data-universalk9-mz.154-1.T1.bin"
Last reload type: Normal Reload
Last reload reason: Reload Command
Cisco 887VA (MPC8300) processor (revision 1.0) with 236544K/25600K bytes of memory.
Processor board ID FCZ1546911N
1 DSL controller
1 Ethernet interface
4 FastEthernet interfaces
1 ATM interface
1 Virtual Private Network (VPN) Module
256K bytes of non-volatile configuration memory.
126000K bytes of ATA CompactFlash (Read/Write)
Hello.
Hi again,
Thank you for your suggestion.  We have changed version to 15.3(3)M4 as you suggested:
xxx.xxx.xxxx.com#show ver
Cisco IOS Software, C880 Software (C880DATA-UNIVERSALK9-M), Version 15.3(3)M4, RELEASE SOFTWARE (fc2)
This seems to have made a difference.  Now, when applying the QoS policy, we get the following message:
xxxx.xxxx.xxxx(config)#int d0
xxx.xxx.xxx(config-if)#service-policy output upstream-policy
Flow Fair Queueing feature is not supported in default class of parent level policy of
xxx.xxx.xxx(config-if)#exit
Any ideas on how we can fix this?
When you mean the underlying physical interface, do you mean the ATM interface?  If so, we tried that (and it does accept the config), however NBAR doesn't seem to work properly on the ATM interface (it does not seem to detect all types of traffic passing through).
Thank you for your help.
Hello.
Try to configure hierarchical QoS, putting shaper into parent policy-map and CBWFQ into the child one.
Not sure if it could help, but you may try.
We have QoS working on the dialer interface.  This is tested and working - when we saturate the upstream, we can still have great ping response times (icmp) - where as before we enabled this, we would have dropped responses.  We went with the following config:
class-map match-any important
 match protocol http
 match protocol icmp
 match protocol imap
 match protocol smtp
 match protocol secure-ftp
 match protocol ssh
 match protocol dns
 match protocol h323
 match protocol rtcp
 match protocol rtp
 match protocol sip
 match protocol skype
 match protocol secure-imap
policy-map outbound
 class important
  priority percent 50
However, when we try to increase priority percent on the policy map, we get:
xxxx.xxx.xxx(config-pmap-c)#priority percent 60
Insufficient bandwidth 1131 kbps for bandwidth percent guarantee
I understand it used to be possible to set max-reserved-bandwidth in older IOS releases but that has been deprecated now.  What is the equivalent command or groups of commands to perform the same action?
Perhaps I spoke too soon - things still seem a little slow with upstream saturated.  Browsing is slow (http) and ping response times are pretty bad.
Is there any way I can test this is working?
I actually have the same problem with the fair-queue not beeing supported in the default class.
My config:
class-map match-all Voice
 match ip dscp ef
class-map match-any CallSignaling
 match ip precedence 3
policy-map WAN-EDGE
 class Voice
  priority 200
 class CallSignaling
  bandwidth 100
 class class-default
  fair-queue
R887-H(config)#int dialer 1
R887-H(config-if)#service-policy output WAN-EDGE
Any idea? Before upgrading to 15.3(3)M4 it did worked fine ...
Thanks ;)
Hello.
As it was mentioned before, try to build hierarchical QoS with shaper in parent policy. I guess this could help you.
Hello Vasilii,
I'm sorry to ask you this but could you provide a basic example?
I'm trying yo configure as you said but I'm afraid I'm not doing it right :(
What I've done so far:
class-map match-any alltraffic
 match ip dscp ef
policy-map ALL_CHILD
 class class-default
  fair-queue
policy-map WAN-EDGE
 class Voice
  priority 200
 class CallSignaling
  bandwidth 100
 class alltraffic
   service-policy ALL_CHILD
Result:
 Cannot attach queuing-based child policy to a non-queuing based class
R887-H(config-if)#
I'm afraid I don't understand the implications of bandwidth and priority on policing and shaping...
Thanks for your help!
François Van Ingelgom
Hello.
It's like following:
policy-map CHILD
class Voice
  priority 200
 class CallSignaling
  bandwidth 200
 class class-default
  fair-queue
policy-map PARENT_SHAPE
 class class-default
  shape average 2000000
   service-policy CHILD
Wow thanks!
It works fine, many thanks!
I just have a question:
The traffic gets first shaped and then prioritized? As I've read shaping might induce latency on packet treatment. How is traffic queued in such a configuration?
Anyway, thanks a lot for your help!
Hello.
First of all the traffic is prioritized; as a result of prioritization scheduler would take packet from priority queue first rather than from any other queue.
Shaping is limiting "how often" the scheduler pick the packet to send through the wire. Queueing is done on per-class basis.
Ian Stephens
I decided to scrap NBAR and the QoS settings above for a much easier fair-queue system.
New config:
policy-map fair-queue-child
 class class-default
  fair-queue 128
policy-map fair-queue-parent
 class class-default
  shape average 900000
   service-policy fair-queue-child
This new config works amazingly - full saturation of upstream and no packets lost while pinging and response times under 30ms even at full saturation.  Before this config, response times could range from 600-900ms.
The key is to get the shape average command right for your upstream bandwidth.  You should go about 80% of your upstream link speed - otherwise it won't work as well.
