Appropriate Use of a Multilink
william-ellison
I have two buildings which are now connected by a Cisco wireless bridge. I’m wanting to put in a second wireless bridge for redundancy and additional bandwidth. Would setting up a multilink connection be appropriate for this implementation?
Patrick Laidlaw
Level 4
Level 4
William,
Multilink is usually used in ppp environments ie multiple T1's between two sites. For your dual wireless bridges you may want to think about setting up two routing interfaces and use eigrp to load balance across them.
Patrick
Patrick,
Thank you. I will look into setting up routing interfaces.
