Archive configs to TFTP server
mmasenya
Hi there
I am struggling to copy running config of a router to a remote tftp server. The tftp server is reachable because i can ping it from the router.
Below is my example of what i am doing;
first pinging the tftp server:
dock-00#ping 192.168.3.24
Sending 5, 100-byte ICMP Echos to 192.168.3.24, timeout is 2 seconds:
Success rate is 100 percent (5/5), round-trip min/avg/max = 36/38/40 ms
Then trying to copy:
dock-00#copy flash tftp
Source filename [c1841-ipbasek9-mz.124-23.bin]?
Address or name of remote host []? 192.168.3.24
Destination filename [c1841-ipbasek9-mz.124-23.bin]?
%Error opening tftp://192.168.3.24/c1841-ipbasek9-mz.124-23.bin (Timed out)
It fails even if i change the destination filename to, for example, "R2"
regards
marce1000
 - For starters the bin file(s) which you specify in the tftp command test don't relate to the running config , which as you state you are trying to copy/backup  to the tftp server, the latter can be achieved with :  # copy running-config tftp://192.168.3.24/config.backup.copy (e.g,).            If that fails too, then also check the logs of the tftp server.
 M.
Leo Laohoo
conf t
 tftp flash:c1841-ipbasek9-mz.124-23.bin
end
marce1000
 M.
in addition to marce1000 post
in some tftp-server implementation you cannot CREATE files in the root -> specify a subdirectory
or you cannot create files at all, -> create an empty file first, then you may be able to overwrite this (and/or create a subdir first.)
the logs of the tftpserver will indicate what the error is.
mmasenya
Guys
Thanx very much for your help. I am sorted and everything works well.
regards
