08-13-2017 03:41 PM - edited 03-05-2019 08:59 AM
Gents,
I'm trying archive download-sw commands to upgrade IE3000 boxes but getting below errors every time. Let me know what can possibly the reason and how to get this sorted out.
Solved! Go to Solution.
08-14-2017 05:37 PM
tftp is reachable from the appliance as I've already checked it by pinging.
If you can ping then check network or Windows firewall.
08-13-2017 04:08 PM
Screenshot shows three distinctive error messages:
Do you have a TFTP server enabled?
08-13-2017 04:15 PM
yes, Leo I've enabled solarwinds tftp server on my laptop.
I've also checked the command syntax and that seems fine with no typos.
What do you think can be the reason of unsuccessful execution.
08-13-2017 04:36 PM
Firstly, "Timed out" means the the appliance can't see the TFTP server. So try pinging from the appliance to the TFTP server. And then check for the presence of a firewall.
08-13-2017 04:43 PM
Do you think there can be another issue? I need to upgrade around 28 units today :(
Your prompt response is going to save a life here :)
08-14-2017 05:37 PM
08-16-2017 11:15 AM
Yes, Leo that was the windows firewall stopping the upgrade process.
Thanks Bro, Cheers!
08-16-2017 01:55 PM
Thanks, Umer.
