Are port numbers following IP addresses in show ip nat translations in dynamic NAT configuration?
Mary Leon
Hello, everyone,
I have noticed there are numbers following the IP addresses in dynamic NAT configuration (see attached picture).
I know in a PAT configuration (overload) those numbers are port numbers. I'm wondering if they are port numbers in dynamic NAT  (I'm using a Packet Tracer project in a 2811 router.
Thank you in advance.
Giuseppe Larosa
Hello @Mary Leon ,
your test traffic is based on ICMP only and ICMP has no port concept that are TCP and UDP specific.
for further reading
https://www.iana.org/assignments/icmp-parameters/icmp-parameters.xhtml#icmp-parameters-codes-9
Hope to help
Giuseppe
Hello, Giuseppe and thank you for your answer.
I'm sorry, of course you're right, ICMP does not manage port numbers.
But, then, what are those numbers following : ?
Excuse me for insisting.
Were you suggesting those numbers following ":" are ICMP codes? Because I don't think so, in my scenario they were just echo request and echo reply and in other tests, numbers were different...
Hello @Mary Leon ,
I actually was thinking this at the beginning, but the values as you have noted do not match with ICMP echo and ICMP echo reply codes that are 8 and 0 respectively.
At this point another possible interpretation of those values are the number of single translations per NAT entry.
I would suggest you to try to investigate in this sense. If you make three attempts to ping an OUTSIDE global address from an INSIDE local host you may get 3.
Here the ICMP entry expiration timer should be much lower then UDP or TCP so each attempt to ping should be seen as a separate NAT hit
Hope to help
Giuseppe
