routing problem
sel18
Hello all,
on this lab, i can't ping to 8.8.8.8 or to the gateway (192.168.2.1).
i want to reach the cloud from any fortigate ( the address of the fortigate is a static address)
also i want to add a default router to the cloud from all the fortigate.
i am working on a local network.
please anyone could help ?
19 Replies 19
balaji.bandi
Post the router config, do you NAT in place in the router ?
BB
router config!
int gi0/0
ip add 192.168.2.130 255.255.255.0
no shu
int gi0/3
ip add 192.168.3.133 255.255.255.0
no shu
ip def-getaway 192.168.2.1
ip route 0.0.0.0 0.0.0.0 gi0/3
what are mean by NAT in place the router ?
if you want your RFC 1918 address to reach internet, they need to NAT, since they are not routable IP address.
Until you have any other device which doint that TASK.  ( as per the picture you using EVE-ng or PNET emulator for this Lab) - so your DSL should do the NAT, or else you need to do NAT on Router
what is NAT explain here good way :
https://www.cbtnuggets.com/blog/technology/networking/networking-basics-what-is-nat
BB
thanks @balaji.bandi ,
i am using eve-ng
did you mean that i should apply just on the the interface for exemple gi0/0 "ip nat inside" and on the interface gi0/3 "ip nat outside" ?
if yes ! i tried it but nothing is changed ! or the config miss another command ?
here is the example - test and advise. ( you should be able to ping 8.8.8.8)
remove this :
no ip def-getaway 192.168.2.1
before deploying below config from Router are you able to ping 8.8.8.8 ?
int gi0/0
ip nat inside
int gi0/1
ip nat inside
int gi0/2
ip nat inside
int gi0/3
iip nat outside
access-list 1 permit 192.168.2.0 0.255.255.255
access-list 1 permit 192.168.4.0 0.255.255.255
access-list 1 permit 192.168.5.0 0.255.255.255
ip nat inside source list 1 interface GigabitEthernet0/3 overload
BB
@balaji.bandi
no i can't ping to 8.8.8.8 that's the problem
Lets start form basic test :
from router you not able to ping  8.8.8.8 correct ?
192.168.1.133 ? you got from DHCP ? what is your PC IP ?  ( as the screen shot you have Lan IP 192.168.2.X /24 ?)
So your router should be in 192.168.2.X  to reach internet - this required to fix.
here good guide to start :
https://www.youtube.com/watch?v=SIZoaEbmXo8
BB
@balaji.bandi
i didn't get the add 192.168.3.133 from dhcp, it's a static address
i try to change the ip of gi0/3 to 192.168.2.130 but still can't ping to 8.8.8.8 from router !
Can you post the router config show run  and what is the results of ping any of your network device ? in the network 192.168.2.X from your Router ?
BB
@balaji.bandi
i try a new address ip for the interfaces
router#sh run
interface GigabitEthernet0/0
ip address 192.168.10.130 255.255.255.0
ip nat inside
ip address 192.168.2.130 255.255.255.0
ip nat outside
ip route 0.0.0.0 0.0.0.0 GigabitEthernet0/3 192.168.2.0
access-list 1 permit 192.168.10.0 0.0.0.255
what is the results of ping to any device in 192.168.2.x
remove below line
no ip route 0.0.0.0 0.0.0.0 GigabitEthernet0/3 192.168.2.0
check ipconfig /all from your PC, what you see the Gateway ? take teh gateway and add below linne
ip route 0.0.0.0 0.0.0.0 192.168.2.X
post  below output :
show run ( FULL - not bit and pieces)
show ip route
BB
@balaji.bandi
the ping to 192.168.2.130 or .128 is working but to 192.168.2.1 didn't work
the gateway is 192.168.2.1
router# sh run
ip nat inside
ip virtual-reassembly in
duplex auto
speed auto
media-type rj45
interface GigabitEthernet0/1
ip address 192.168.30.130 255.255.255.0
duplex auto
speed auto
media-type rj45
interface GigabitEthernet0/2
ip address 192.168.20.130 255.255.255.0
duplex auto
speed auto
media-type rj45
ip nat outside
duplex auto
speed auto
media-type rj45
ip forward-protocol nd
no ip http server
no ip http secure-server
ip route 0.0.0.0 0.0.0.0 192.168.2.1
router# sh ip route
Gateway of last resort is 192.168.2.1 to network 0.0.0.0
S* 0.0.0.0/0 [1/0] via 192.168.2.1
192.168.2.0/24 is variably subnetted, 2 subnets, 2 masks
C 192.168.2.0/24 is directly connected, GigabitEthernet0/3
L 192.168.2.130/32 is directly connected, GigabitEthernet0/3
192.168.10.0/24 is variably subnetted, 2 subnets, 2 masks
C 192.168.10.0/24 is directly connected, GigabitEthernet0/0
L 192.168.10.130/32 is directly connected, GigabitEthernet0/0
192.168.20.0/24 is variably subnetted, 2 subnets, 2 masks
C 192.168.20.0/24 is directly connected, GigabitEthernet0/2
L 192.168.20.130/32 is directly connected, GigabitEthernet0/2
192.168.30.0/24 is variably subnetted, 2 subnets, 2 masks
C 192.168.30.0/24 is directly connected, GigabitEthernet0/1
L 192.168.30.130/32 is directly connected, GigabitEthernet0/1
192.168.2.1   - Device should able to ping gateway before you proceed any further.- this more of your eve-ng setup issue. ( make sure you watch the video closly) the interface should map correctly.
is this your first time setup with eve-ng (it worked before ?)
From your PC you able to ping  192.168.2.1 and have internet ?
from eve-ng you able to get to 8.8.8.8 ?
BB
@balaji.bandi
i worked before with the eve but the issue is for the first time
yes i can ping to 8.8.8.8 from eve-ng
yes i can ping to 192.168.2.1 and to internet from my PC
PS: when i connected the fortigate with the cloud (without an router) is working and i can managed the fortigate
so i thing the problem is in the router ?
