ARP Spoofing attack
balaji_170
Hi all,
can anybody give conclusion , how switch can able to prevent ARP spoofing attack without DHCP snooping information
> Switch will verify all packets of the untrusted ports - whether its carry valid IP to MAC address - with help of DHCP snooping informations
in my case , DHCP snooping informations are absent  - how can i block ARP spoofing attack
if anybody have answer -please give with example and if it possible with documents
M.R.BALAJI
Jeff Van Houten
Level 5
Level 5
You could use Mac acls, but that is a very manual process if your hosts change port assignments very much.
