AS PrePend
Network Pro
can someone please throw some light on AS Prepend in BGP multi homing. I understand its for forcing traffic through Primary ISP but does the Prepend need to happen on ISP side or customer side routers ? will this work for incoming and outgoing traffic ?
Also what are the other ways to implement the same ?
does anyone has sample config for the above ?
31 Replies 31
Here it go,
The path to 4.4.4.4/32, will be preferred through ISP 1 because R1 is announcing to its iBGP domain a local preference of 25000 (greater is better) and R1 is advertising to the ISP1 a smaller ASPath Prepend, so it will desired for the prefixes coming from behind of ISP1 and 2.
The opposite to R2.
R1
router bgp 100
bgp log-neighbor-changes
neighbor 10.12.0.2 remote-as 200
neighbor 10.12.0.2 route-map LP in
neighbor 10.15.0.5 remote-as 100
neighbor 10.15.0.5 next-hop-self
neighbor 10.15.0.5 route-map PREPEND out
ip forward-protocol nd
no ip http server
no ip http secure-server
route-map LP permit 5
match ip address 10
set local-preference 25000
route-map PREPEND permit 5
match ip address 10
set as-path prepend 400 400
access-list 10 permit any
R2
router bgp 100
neighbor 10.15.0.1 remote-as 100
neighbor 10.15.0.1 next-hop-self
neighbor 10.35.0.3 remote-as 300
neighbor 10.35.0.3 route-map LP in
neighbor 10.35.0.3 route-map PREPEND out
no ip http server
match ip address 10
set local-preference 5000
match ip address 10
set as-path prepend 400 400 400 400 400
Please check the picture, if you shutdown the P2P between R1 and R5 you will see that the best path to 4.4.4.4/32 changes, Now it is through R5.
>> Marcar como útil o contestado, si la respuesta resolvió la duda, esto ayuda a futuras consultas de otros miembros de la comunidad. <<
Also if you are going to connect these BGP routers to Internet, take in consideration this:
http://www.cisco.com/c/en/us/support/docs/ip/border-gateway-protocol-bgp/23675-27.html
thanks for lab again - slightly confused in your diagram isnt R1 and R2 customer routers?
so i am talking about a scenario where R1 and R2 are Customer routers connected to each other running HSRP and on same BGP domain.
R3 and R4 are two independant ISP.
Now i want my traffic going through to R3 (primary) and return traffic coming through R3, if R3 is down then i want traffic going through R4 and return traffic coming through R4
Yes, you can configure HSRP on my topology,  where R1 and R2 belong to the same iBGP domain.
To use local preference and as-path to guarantee the symmetric traffic.
With greater local preference and smaller AS-path prepend you are guarantee the traffic go and come back through R3.
With smaller local preference and greater AS-path prepend you are guarantee the back up path.
A highest local preference is always preferred.
A lowest AS-Path prepend is always preferred.
if R3 is down all the traffic will be moved to R4 automatically.
so as per you diagram R1 and R5 are customer routers, is this correct?
R2 and R3 are ISP routers, is this correct?
do i need any sort of config or AS Prepend onR2 and R3 isp routers
Apologies, yes, R1 and R5 are the costumer routers on my diagram  :-)
With my config the vendor is not involved, you have the full control to manipulate the traffic, vendor is not involved to decisions.
R2 and R3 have basic configuration, nothing special.
that clears it up - let me lab this up and get back to you - could you please send me the config for R1/R2/R4 and R5 please?
Sure, I will share it with you
R1
router bgp 100
neighbor 10.12.0.2 route-map PREPEND out
match ip address 10
match ip address 10
R2
router bgp 200
neighbor 10.12.0.1 remote-as 100
neighbor 10.24.0.4 remote-as 400
R3
router bgp 300
neighbor 10.34.0.4 remote-as 400
neighbor 10.35.0.5 remote-as 100
R4
router bgp 400
network 4.4.4.4 mask 255.255.255.255
neighbor 10.24.0.2 remote-as 200
neighbor 10.34.0.3 remote-as 300
R5
router bgp 100
match ip address 10
match ip address 10
Thanks will lab it up and get back to you :)
i labbed it up but cant seem to ping 4.4.4.4 from R1 - i could from R5
checked the routing from R5 says - it goes through R1 but for some reason cant ping from R1 ?
On R1 advertise the loopback 0 on its BGP process, the same for R5, R5's loopback must be advertised under the BGP of R5
and try:
R1
ping 4.4.4.4 source 1.1.1.1
R5
ping 5.5.5.5 source 4.4.4.4
just wondering why does the failover take a long time (around a minute) from when i shutdown R2 (Primary ISP) router ?
fallback is quick
BGP usually takes a long time to terminate the session, you could use fall over. You can also use: clear bgp * soft  to make a soft refresh on the RIB.
Please see this link:
http://www.cisco.com/c/en/us/td/docs/ios/12_0s/feature/guide/cs_bsfda.html
Thanks, i was thinking of BGP timer
how quick does the fallover command reduce to ? is this needed on both routers?
