AS prepnd for some prefix in ASR1002X
Hi want some prefix normal announe no prepend and another announce by prepend to Ebgp
I define prefix list and add normal prefix to the prefixlist for example prefix-list normal
router-map ramin permit 5
ip math normal
continue
router-map ramin permit 10
ip match prepend
set prepend last-as 6
and assing route-map to out neighbor
but this is not working
How Solve this ???
Hi admin@atrinnet.net ,
Sorry for the previous message saying it would not work. I am doing too many things at the same time.
Your command should work. I would just recommend you do "clear bgp ipv4 unicast * soft out"  on the router connected to the Internet after doing any route-map modifications.
11 Replies 11
Harold Ritter
Just remove the continue statement and it should work.
In router-map IF remove continue
For example only ip math prefix-list normal
Go to other rule ?
no action define in this sequence
Work ? announce normal prefix to upstream ?
Go to other rule ?
All prefixes not matching prefix list normal automatically go to the next route-map instance. Prefixes matching prefix list normal are  accepted, but not modified.
Try something like this:
ip prefix-list normal seq 5 permit 1.1.1.0/24
ip prefix-list normal seq 10 permit 1.1.2.0/24
ip prefix-list prepend-5 seq 5 permit 1.1.3.0/24
ip prefix-list prepend-6 seq 5 permit 1.1.4.0/24
route-map ramin permit 10
match ip address prefix-list normal
route-map ramin permit 20
match ip address prefix-list prepend-5
set as-path prepend 100 100 100 100 100
route-map ramin permit 30
match ip address prefix-list prepend-6
set as-path prepend 100 100 100 100 100 100
route-map ramin deny 40
I define this route-map
show route-map ramin
route-map datacenter, permit, sequence 5
Match clauses:
ip address prefix-lists: normal
Set clauses:
Policy routing matches: 0 packets, 0 bytes
route-map datacenter, permit, sequence 20
Match clauses:
ip address prefix-lists: prepend
Set clauses:
as-path prepend last-as 5
Is this work?
This statement will not work, as the as-path is empty when received from iBGP, so last-as is empty.
You should use that instead as I suggested in my previous post:
HI agian define this
route-map ramin, permit, sequence 5
Match clauses:
Set clauses:
route-map ramin, permit, sequence 10
Match clauses:
ip address (access-lists): prepend
Set clauses:
as-path prepend 6500 6500 6500 6500
but not working
Can you provide the prefix lists (normal and prepend) and the bgp configuration to see how you apply the route-map?
router bgp my as
adress family ipv4
neighbor X.X.X.X router-map ramin out
is ok???
Are you admin of this router ?
What you share is rpl of ios xr and asr1002 run ios xe???
MHM
Hi Sure
ASR1002X-Ramin uptime is 13 weeks, 1 day, 2 hours, 1 minute
Uptime for this control processor is 13 weeks, 1 day, 2 hours, 4 minutes
System returned to ROM by Reload Command
System restarted at 17:23:41 UTC Wed Mar 13 2024
System image file is "bootflash:/asr1002x-universalk9_noli.16.12.08.SPA.bin"
Last reload reason: Reload Command
