AS5300 module help
hannyong
Is there any difference between
AS53-4CT1 and an AS53-4ET1 Card? Can I use any card and issue a command to change it from a T1 to en E1 card? How can I physically & visually spot the difference between a T1 and E1 card?
Hann Yong
Richard Burts
Hann
E1 and T1 are quite different. There is not any command that will change a card from T1 to E1. The easy way to spot the difference is to look at the label on the card.
Rick
Rick
Hi Rick,
Thanks for the reply, have you encountered the command "set trunk e1" to change AS53-C4T1 to an E1 card?
Hann Yong
